RiderForums.com Community
Go Back   RiderForums.com Community > Kawasaki Z1000, Z750 & Z-750S > Z1K/Z750 Maintenance
Reply
Thread Tools Display Modes
Old 12-03-06, 03:55 PM   #1
lmj301
Rising Star
Talking spark plugs coil stick (long)
I changed my plugs today (finally). this operation is mostly straight forward except for the #3 coil stick. i am including pix on how i did the #3 since i could not find much other that "be patient"
take off the t-stat bracket bolt and unplug the t-stat wire plug. lift up t-stat housing. lift up the electrical plug (white) so that it is above the frame.
1st pic
i tied up the clutch cable to the faring (z750s) so that it was out of the way
2nd pic
then i tied the electrical harness to the throttle body sensor to bring the harness lower and out of the way.
3rd pic
then with a little fanaggling and cursing the coil stick will lift out through the top of the frame. notice the plug to the spark plug harness is unplugged and bent up.
4th pic
then i used the spark plug tool in the kit and used it in between the top of the engine and the frame.
thanks kawabiker
lmj301 is offline   Reply With Quote
Old 03-19-07, 03:18 AM   #2
swoof
Up-And Comer
You still haven't gotten the pics up??
swoof is offline   Reply With Quote
Old 03-19-07, 09:42 AM   #3
lmj301
Rising Star
no one cared to explain how, and i gave up.
Old 03-19-07, 10:33 AM   #4
kawamania
Supreme Being
how many miles on your plugs? what kind of shape where they in? I was thinking of changing mine but they only have 8000 mileson them and bike runs great. so I have not bothered yet.
kawamania is offline   Reply With Quote
Old 03-19-07, 03:40 PM   #5
lmj301
Rising Star
plugs were in pretty good shape. the center electrode was worn though.
Old 03-19-07, 06:46 PM   #6
RS117
Supreme Being
RS117's Avatar
To attach pics when you are starting a thread or replying to thread scroll down to additional options. Go into manage attachments you can browse and upload pics from there.
__________________
03 Z1000 in perfect Orange W/ CUSTOM GHOST FLAMES -n-SWEET CUSTOM DENT
Hel SS lines in perfect orange
CRG LS mirrors / Renthal Ultra Lows / Shogun frame sliders / HD case sliders
Black Pazzo Shorty Levers / LP turn signals / PC'ed pieces & parts / DIY fender elim.
Black face plate cover (Thanks Goodrode)
custom dogbones / throttle quickener / BMC air filter
02 ZX9R master cylinder
06 ZX636 limited rear shock / 06 ZX636 forks w/ RaceTech 1.0 springs / 06 ZX 636 calipers
2006 ZX10 clutch perch / 2007 ZX10 wheels
/ Clear Alternatives rear integrated / hyper Pro steering dampener
Gilles rear sets with passenger pegs
PC111 w/ full MUZZY = 127.3 HP w/ 66.9 torque
just added Speedo healer / 520 +4 chain conversion w/ Stealth rear sprocket
RS117 is offline   Reply With Quote
Old 03-20-07, 08:56 AM   #7
kwakbiker
Rising Star
kwakbiker's Avatar
What RS said
__________________
Fun is a Black Z1000
Saying hello from sunny England
Uk Z1000 forum
http://www.z1000uk.proboards52.com/index.cgi
kwakbiker is offline   Reply With Quote
Old 03-20-07, 10:38 AM   #8
lmj301
Rising Star
thanks
Old 01-07-08, 06:24 AM   #9
cmit37
Newbie
Thanks for the instructions! I used them yesterday to do the z750's 15000 mile service. I managed to change the plugs, air filter, oil and oil filter but after 30 minutes of trying to slide the top of the engine out of the way so I could measure the valve clearances I lost the will to live and gave up on checking them.
Do you have to remove everything above the engine before you can get the top engine cover off? Thermostat, hoses etc? Has anyone done it and would you recommend me having another stab at it (not looking forward to it) and how many hours would a dealer charge you for checking the clearances and syncing the throtle bodies?
__________________
Black 2005 Kawasaki Z750S
ex 2002 Suzuki GS500 K2, 2001 Piaggio X9 125, 2004 Taishan Commuter 50cc
cmit37 is offline   Reply With Quote
Old 03-31-08, 06:12 PM   #10
falcn
Supreme Being
falcn's Avatar
check the new valve adjustment how-to thread
__________________
Admin @
Racing is an addiction only cured by poverty.
2005 Z750 R
Z750S with the following changes: 2006 ZX6R Limited Edition Forks • 2006 ZX6R Front Rim • 2007 Z1000 Triples • Powerbronze Carbon Fiber Fender • 2007 ZX14 Front Brake Rotors (310mm) • 2006 YZF-R6 Monoblock Brake Calipers • HEL Braided Lines, Black • 2006 ZX6R Swing Arm • 2006 ZX6R Shock • Skidmarx Carbon Fiber Hugger • 2006 ZX6R Rear Rim • 2002 ZX9R Master Cylinder • 2003 ZX9r Clutch Perch• CRG Shorty Levers, Black • Rizoma MC Aluminum Anodized Reservoirs front and rear • Probolt Blue Gas Tank Filler Aluminum Bolt kit • Probolt Blue Engine Case Aluminum Bolt kit • Rear swingarm/suspension lift dog bones • Arrow NiChrom conical slip-on • Scottoiler Mk7• Powder Coated Case Covers
falcn is offline   Reply With Quote
Old 04-04-08, 09:53 PM   #11
Expat
Site Elder
Expat's Avatar
Changed mine tonight, it is fiddly but nothing a few skinned knuckles didn't take care of! Glad I don't do it everyday!
__________________
Expat.
Black 03 Z1000.
Shortened CF Akrapovic slip ons. K&N filter + air box mod. Powercommander III.
Speedohealer. Twin light conversion. Renthal ultra lows. Bar end mirrors. Tail tidy. Sargent seat.
Renntec grab rail (only fitted when passengers are on!) Shock racing LED mini turn signals.
Throttle quickener. Motovation frame and fork sliders.
Rizoma case sliders. Shorty Pazzo levers. Hyperpro RSC damper. Driven +3 520 chain conversion
06 ZX10R wheels with stock wavy rotors.
Custom stainless steel wheel spacers, footpeg pins, bar dampers and caliper spacers.
06 ZX10R front and rear brakes.
Black HEL lines with Red fittings.
07 Silver ZX6R forks with Race Tech .95 springs.
06 ZX6R shock. 06 ZX6R front fender.
05 GSXR600 Track bike
94 Yamaha RZ350 restoration project....
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Expat is online now   Reply With Quote
Old 04-06-08, 04:32 PM   #12
climb21cj
Site Elder
climb21cj's Avatar
^^^ +1
skinned knuckles is all you need, cursing does help, the louder the better. i did mine at 12k and will probly do them sooner after running ultra rich for 1k miles before i got my dyno tune
__________________
go green, or go home
latest news:
I'm back on the road again! Still have a fear of buses.
climb21cj is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2009 RiderForums.com
