| Register | FAQ | Members List | Calendar | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
Supreme Being
Z1000 w/636 forks - pics
This isnt my Z1000, even though I wish it were.
I figured Id post the links incase anyone was interesting is seeing them.636 Forks sitting next to Z1000 - http://www.labusas.org/photopost/dat...Forks.jpg?3220 http://www.labusas.org/photopost/dat..._forks.jpg?189 Triple clamps- http://www.labusas.org/photopost/dat...lamps.jpg?8977 636 Brakes- http://www.labusas.org/photopost/dat...z_600.jpg?6345 636 Forks installed on Z1000- http://www.labusas.org/photopost/dat...z_700.jpg?8728 Here is some more information about the install. http://www.labusas.org/phpBB2/viewto...1000+636+forks
__________________
Racing Rice ***SOLD*** Z1000.. Big on Fun, not on plastic! DL650K5.. More versatile then Duct Tape. 1978 XS650.. Project Hardtail bobber 1982 XS650.. Project Brat bike Last edited by Racing Rice : 01-25-04 at 11:12 AM. |
#2 |
Rising Star
Location: Augusta GA, home of the Masters. Too bad I don't like golf.
Pretty cool. It only needed minor modifications to make it fit. Also, he needed to raise the rear to compensate for the longer forks. If I had the time and money....
#3 |
Supreme Being
My only problem with the whole thing is, if it were any taller I wouldnt be able to touch the ground. Man it sucks being vertically challenged.
__________________
Racing Rice ***SOLD*** Z1000.. Big on Fun, not on plastic! DL650K5.. More versatile then Duct Tape. 1978 XS650.. Project Hardtail bobber 1982 XS650.. Project Brat bike |
#4 |
Rising Star
Were the stock rotors used? Or are those the rotors off the 636?
__________________
Post-deer repairs complete!! Rochester, New York |
#5 |
Supreme Being
They almost look like stock rotors, but Im not 100% sure about that. The front rotors on the 636 are only 280mm, while the Z uses 300mm rotors.
__________________
#6 |
Up-And Comer
Exactly the reason I didn't do this mod! I had access to a set myself, but opted out after measurements.
I didn't read the link, but I can tell you from my measurements, that there is a bout a 2" in difference in length!!! The only way I would do this is if I converted to clip-ons. You can really see the difference in height if you put the before and after pics side-by-side and look at the distance between fender and headlight. |
#7 | |
Newbie
Quote:
#8 | |
Newbie
Quote:
Have heavier springs to compensate for heavier bike and rider. Raised rear a total of 3/4 " by welding and re-drilling dogbones, and adding more pre-load to rear shock. One reason for mod is that I was dragging the pegs, even hanging off like a circus monkey. Picture, below, was taken at Palomar Mountain, Ca Stock forks were compressed about 50 %. |
#9 | |
Newbie
Quote:
#10 |
Supreme Being
I think I'll wait to get a set off the 2004's with the DLC (Diamond-Like Coating)
__________________
2006 Buell City X Support Orange Appeal! Z1000, Z750, Ninja Throttle quickeners now available at motospecialties.com! |
#11 |
Rising Star
I think a set of rotors of a ZX9 will bolt up. I belive they are also 10mm bigger than the Z's....You would need some sort of caliper spacer though....
__________________
Thanks, Dapper |
#12 |
Supreme Being
Glad you could join us C. Dolan! I was hoping you would sooner or later.
Welcome to the site.
__________________
#13 | |
Newbie
Quote:
If that were the case, then 15 mm spacers would be needed instead of 10 mm spacers. The OEM Z-1000 rotors work just fine, and are already in hand with stock wheel . I have stainless lines made up at Earl's Supply, and Carbone Lorraine brake pads. 636 rotors have totally different bolt pattern. |
| Thread Tools | |
| Display Modes | |
