RiderForums.com Community
Go Back   RiderForums.com Community > Kawasaki ZR-7 > General ZR-7
Reply
Thread Tools Display Modes
Old 09-08-04, 06:06 PM   #1
dklay
Timex
dklay's Avatar
Annoying little things
Since I've been doing a bit of carb work and maintenence lately, here's some things that I've found about the ZR-7 that are annoying. They suggest to me that the bike was designed by engineers with very little consult to mechanics, who actually have to take the things apart.
1. The rear gas tank bracket that bolts to the frame. Couldn't they have designed it so that you don't have to remove it to be able to get inside the airbox???
2. You have to remove the cover(s) from the airbox (as well as the previously mentioned bracket) in order to get at the battery.
3. Why couldn't the throttle cables attach at the top of the carburetors, so they could be easily disconnected? It's truly a pain in the butt to get them disconnected and connected again- I've had to disconnect the cables at the throttle grip to get enough slack to re-connect them
4. If there were about 1/2" more play between the airbox mixing chamber and the frame rail, you'd be able to just slide the airbox backwards to get the carbs out.
5. Phillips screws. They strip WAY too easy. Would it be so hard to use hex heads or allen heads everywhere?
6. The spacers that go between the wheel and the swingarm/ fork tubes. Seems every time I try to re-mount a wheel, I fight with these things - knocking one out of place while trying to slide the wheel up and simultaneously slipping the axle back in.
I'm sure there are other things, but those are the first to come to mind right now. Other than that, the bike's great!!
dklay is offline   Reply With Quote
Old 09-08-04, 08:02 PM   #2
graeme gould
Maintenance Overlord
graeme gould's Avatar
Hi dklay
Sounds like you have been tinkering with the carbs and the back wheel.
I always seem to have trouble with the front wheel alignment of the speedo drive and fork guide.
gg@lamchabang, ava good day
__________________
Graeme Gould at Byron Bay the most Easterly part of Australia
graeme gould is offline   Reply With Quote
Old 09-08-04, 08:13 PM   #3
madbam
Up-And Comer
madbam's Avatar
Yeah dk
Yeah...I fully agree with #'s 1 and 2 since I had to get a new battery recently....what a pain in the A$%
__________________
J--E--T--S...Jets..Jets.Jets
madbam is offline   Reply With Quote
Old 09-08-04, 09:53 PM   #4
javasutra
Silver Member
javasutra's Avatar
I've been through all six and I agree. The airbox situation is probably my least favorite.
GG, I've been wondering about that speedo drive lately. When I put it on seemingly according to the manual, the speedo cable seems to be very kinked near the hub. It was this way from the shop so I've always assumed that it was the right way. It seems, though, that the coupling for the cable should be closer to the ground so the cable is less stressed.
javasutra is offline   Reply With Quote
Old 09-08-04, 10:20 PM   #5
Bronto
Supreme Being
Bronto's Avatar
Agree with #1. Only salvation was discovered a phillips screw driver will fit the allen hex bolt. Enough to loosen or tighten a little, when its loose.
Someone was saying changing the spark plugs on a Ducati, nearly had to remove the engine. So it could be allot worse
__________________
Semi Truck air flow Video.
______________________________Alan____
Red Zx6r & Green GSX1300R - Former Blurple Zr7sS rider
Bronto is offline   Reply With Quote
Old 09-09-04, 08:14 PM   #6
graeme gould
Hi Java
If you feel it is "kinked" more than likely it is, have a look at another zr7 or some friendly forumer may post a pic of the speedo cable to axle connection. As I remember the cable enters the drive at about 20 degrees below the horizontal
gg@lamchabang Thailand
__________________
Old 09-10-04, 10:06 AM   #7
javasutra
Silver Member
javasutra's Avatar
I definitely have it wrong, then. My cable is entering the drive about 20 degrees above horizontal. I'll loosen the axle and see if I can get it rerouted.
Old 09-10-04, 12:48 PM   #8
javasutra
Silver Member
javasutra's Avatar
I have another one to add to the list. This one is probably Keihin's fault but..
7. The drain screws on the carbs all point to the right. This makes it a real challenge to get to #1 and #2 to drain the bowls.
Regarding number 4, I pulled the boots out of the airbox before removing the carbs the last time. They're something of a pain to get back in but the carb bank comes out and goes in much, much easier with the boots off.
Old 09-10-04, 10:05 PM   #9
graeme gould
Yes Java
Those carb drains screws are trickey, I removed the carb heaters permantely to give me better access.
gg@lamchabang T'land, ava good day
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2009 RiderForums.com
