RiderForums.com Community
Go Back   RiderForums.com Community > Kawasaki Z1000, Z750 & Z-750S > Z1K/Z750 Maintenance
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 08-21-08, 02:30 AM   #1
nf_ekt
Supreme Being
nf_ekt's Avatar
Minimum required tensile strength for Z1000 chain?
Ok, so my stock chain and sprockets are pretty much done, and I need to put on new parts while on a budget.... so can anyone tell me what the tensile strength requirements are for the Z as far as the chain goes? So far I have sourced out steel sprockets from sprocket specialists (37.99 rear, 22.99 front), just not totally sure on the chain yet.
I dont mind constantly lubing a non-sealed chain, I just need to save some money right now.
If anyone knows the cheapest place to buy this stuff, by all means lmk. Thanks.
P.s. I tried looking up the stock chain on google (EK525 UVXL) and came up with nothing, oh well.
From what I can gather so far I guess I need 8500 lbs. tensile strength or better, anyone that knows for sure pls. chime in.
__________________
Muzzys exhaust...."Can you hear me now? GOOD!"
CMTBD
'05 636 forks, fender & shock-Scotts steering damper- Renthal ultra-lows-Crg mirrors-Nbm Woolford SS Lines-PC3-K&N-AB Mod-HitJohn sliders-Custom case sliders- Kawi extended shield-Road2 rear/2CT front -Custom black CF style (diy) seat cover- Renthal sprockets-Acumen DG8- Integrated tail light- Lots of black and more to come.
nf_ekt is offline   Reply With Quote
Old 08-21-08, 08:25 AM   #2
Jason 306
Supreme Being
Jason 306's Avatar
Well I dunno about all those numbers and stuff. But I go here
http://www.sprocketcenter.com/c/1620...000-03-06.html
Go with a D.I.D. chain and call it a day, probably the best chain there is.
__________________
Jason 306 is offline   Reply With Quote
Old 08-23-08, 11:41 PM   #3
INTHERED
Supreme Being
INTHERED's Avatar
Quote:
You can probably get by with 8000 to 8500 on the Z1000 but why go with the minimum when you can get a gold ek 9200 chain on ebay for $99 with free shipping ?
http://cgi.ebay.com/ebaymotors/GOLD-...spagenameZWDVW
The higher strength chains give you a bigger safety margin, require less frequent adjustment and only cost a few dollars more.
When it comes to buying sprockets I like to stick with OEM on the front since they have the rubber dampener which cuts down on chain noise and if you are going to switch to a 15 tooth on the front you can get one off a 2007 Z1000. The rear sprocket I went more for looks so I got a gold anodized unit from Sprocket Specialties which is holding up quite well but will never outlast the steel ones.
inthered
__________________
2008 ORANGE/BLACK FXDL, Vance & Hines Slipons, XIEDs, SE Heavy Breather AC
SOLD! 2003 ORANGE Z1000, Yosh Slipons, PCIII, K&N w/stage 2 airbox
INTHERED is offline   Reply With Quote
Old 08-24-08, 12:51 AM   #4
jarhead_115
Up-And Comer
jarhead_115's Avatar
Here is the stocker, probably better to go aftermarket....http://www.babbittsonline.com/pages/.../Kawasaki.aspx
__________________
2007 Z1000.
Air box mod.
Blacked out.
OEM seat cowl.
Home made shortie levers.
Custom fender eliminator.
Flush mount blinkers, front, rear.
Rizoma frame sliders.
Corbin seat.
Rizoma grips.
jarhead_115 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 RiderForums.com
