RiderForums.com Community
Go Back   RiderForums.com Community > Kawasaki Z1000, Z750 & Z-750S > Z1K/Z750 Maintenance
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 02-19-08, 08:14 PM   #1
falcn
Supreme Being
falcn's Avatar
Knock out pin removal
Items marked 13, 24 need to come out of the caliper bolt holes for these to go onto my 636 forks.
Any suggestions?
They won't come out when gripped by a wrench from the outside, already tried the dry-ice on them, no budge....
anything else?
__________________
Admin @
Racing is an addiction only cured by poverty.
2005 Z750 R
Z750S with the following changes: 2006 ZX6R Limited Edition Forks • 2006 ZX6R Front Rim • 2007 Z1000 Triples • Powerbronze Carbon Fiber Fender • 2007 ZX14 Front Brake Rotors (310mm) • 2006 YZF-R6 Monoblock Brake Calipers • HEL Braided Lines, Black • 2006 ZX6R Swing Arm • 2006 ZX6R Shock • Skidmarx Carbon Fiber Hugger • 2006 ZX6R Rear Rim • 2002 ZX9R Master Cylinder • 2003 ZX9r Clutch Perch• CRG Shorty Levers, Black • Rizoma MC Aluminum Anodized Reservoirs front and rear • Probolt Blue Gas Tank Filler Aluminum Bolt kit • Probolt Blue Engine Case Aluminum Bolt kit • Rear swingarm/suspension lift dog bones • Arrow NiChrom conical slip-on • Scottoiler Mk7• Powder Coated Case Covers
falcn is offline   Reply With Quote
Old 02-19-08, 08:24 PM   #2
Jason 306
Supreme Being
Jason 306's Avatar
Would some sort of oversized easy-out be able to somehow twist them out? I guess there's a ledge in there that prevents a punch from sliding down in there or a mini-slide hammer?
__________________
Jason 306 is offline   Reply With Quote
Old 02-20-08, 06:23 AM   #3
falcn
Supreme Being
falcn's Avatar
I have the Pit Posse wheel bearing remover which has split "cones" that fit into the inside of the bearing and expand when you smack a screwdriver like tip rod into the gap. This expands and grips the metal and works really well....for wheel bearings...kind of like a mini-slide hammer effect.
I tried it last night, and the knock out pins didn't budge one iota. There is no lip, the 10.5mm inside diameter is the same as the rest of the bolt hole bore.
__________________
Admin @
2005 Z750 R
Old 02-20-08, 08:06 AM   #4
junglejim
Up-And Comer
Maybe try PB Blaster or something like it. If all else fails get out the dremmel and cut through it verticaly (careful not to cut into the caliper). Then you should be able to colapse it and pull it out. Hope this helps.
junglejim is offline   Reply With Quote
Old 02-20-08, 08:34 AM   #5
falcn
Supreme Being
falcn's Avatar
Yeah I will try my PB Blaster - but don't think it is stuck because of corrosion or dirt, so I have low expectations of that working.
It will be very difficult to get to the inside of the pin with a dremel to cut it to collapse it (this is what I had been saving as my last resort).
__________________
Admin @
2005 Z750 R
Old 02-20-08, 10:18 AM   #6
junglejim
Up-And Comer
Thread it with a tap. Then you can put a bolt in it and drive it out from the back side.Its a long shot but mehh I've seen stranger things work.
Old 02-20-08, 10:24 AM   #7
falcn
Supreme Being
falcn's Avatar
That's not a bad idea. I believe for a 10.5mm opening it would have to be a 12.5 x 1.75 tap.
....or I could weld something across the opening and drive it out. If I had a welder....
If I had a drill press with vice I guess I could start drilling them out until thin enough to remove. I need more tools!!
__________________
Admin @
2005 Z750 R
Old 02-20-08, 11:24 AM   #8
junglejim
Up-And Comer
Its a 12x1.75 or 12x1.5 will work in a 10.5 hole. If its soft enough material you may be able to use a 1/2-13 tap. Hope they aren't hardened steel inserts or tapping is out. You will ALWAYS need more tools!!! Yeah tig welding a plug in the end would work well. Good luck.
Old 02-20-08, 12:12 PM   #9
falcn
Supreme Being
falcn's Avatar
They don't appear to be hardened metal, I can surface dent them with my pliers.
__________________
Admin @
2005 Z750 R
Old 02-20-08, 12:55 PM   #10
Expat
Site Elder
Expat's Avatar
You can get a cheap set of stud extractors at Sears, they have a left hand thread on them, use a tap wrench to screw the exractor in, it will bite and hopefully spin the bush as it is not threadded... can you apply heat? The alloy will expand much faster than the bush which will also help. Watch the seals though!
Good luck.
__________________
Expat.
Black 03 Z1000.
Shortened CF Akrapovic slip ons. K&N filter + air box mod. Powercommander III.
Speedohealer. Twin light conversion. Renthal ultra lows. Bar end mirrors. Tail tidy. Sargent seat.
Renntec grab rail (only fitted when passengers are on!) Shock racing LED mini turn signals.
Throttle quickener. Motovation frame and fork sliders.
Rizoma case sliders. Shorty Pazzo levers. Hyperpro RSC damper. Driven +3 520 chain conversion
06 ZX10R wheels with stock wavy rotors.
Custom stainless steel wheel spacers, footpeg pins, bar dampers and caliper spacers.
06 ZX10R front and rear brakes.
Black HEL lines with Red fittings.
07 Silver ZX6R forks with Race Tech .95 springs.
06 ZX6R shock. 06 ZX6R front fender.
05 GSXR600 Track bike
94 Yamaha RZ350 restoration project....
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Expat is online now   Reply With Quote
Old 02-20-08, 01:30 PM   #11
falcn
Supreme Being
falcn's Avatar
http://www.sears.com/shc/s/p_10153_1...stud+extractor
if you mean something like this kit, I don't think the brittle extractors will be up to the tast. Hell half the time i try to use them to remove stuck screws they snap.
__________________
Admin @
2005 Z750 R
Old 02-20-08, 01:59 PM   #12
Expat
Site Elder
Expat's Avatar
Thats where the heat comes in. They have to be hard (which = brittle) to bite into the surface. They are made from the same steel as a tap or die, be gentle, they only snap if you are too heavy handed! (no insult intended!)
__________________
Expat.
Black 03 Z1000.
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Old 02-21-08, 08:30 AM   #13
falcn
Supreme Being
falcn's Avatar
got a tap set from a friend. He had a good idea to expand on the tapping idea.
once tapped, use a short pipe, and a couple washers. Use the pipe as leverage against a nut to lift out the pin rather than knock it from the back side.
__________________
Admin @
2005 Z750 R
Old 02-21-08, 06:31 PM   #14
falcn
Supreme Being
falcn's Avatar
Well none of the above!!
I started to try and tap one, but it just started spinning.
I then took the caliper over to the workbench and figured, and thought "Well they are pretty soft metal..."
I got out my trusty cold chisel and put down some padding under the bottom of the side of the caliper and started hitting the side of the knock out pin. It started deforming and popped out of the bore!! I did the other 3 and now my calipers are knock out pin free!
I tested the alignment with the ZX6R fork leg mounts and they look SWEEEET! They line up perfectly.
__________________
Admin @
2005 Z750 R
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 RiderForums.com
