Scorpion helmet tight fit
This is a discussion on Scorpion helmet tight fit within the Riding Gear forums, part of the General Forums category; A couple of months ago I purchased a Scorpion helmet in the same size as the HJC CL-14 helmet I purchased when I got my ...
Results 1 to 6 of 6
    Rising Star ScooterDog's Avatar
    Sep 2006
    289
    A couple of months ago I purchased a Scorpion helmet in the same size as the HJC CL-14 helmet I purchased when I got my bike. The Scorpion seemed a little tight, but I chose it instead of going up a size, trying to anticipate that the padding might compact a little with wear.
    Well, the padding has not compacted, but I am having a hard time going back to the HJC. I'm now used to the Scorpion's tighter fit, but the air flow is much better than the HJC's; the shield will stay in the partially open position even at highway speed; changing from the smoke to the clear screen (for those days when I work laaaaaaaate) is so simple, even I can do it; wind noise is tremendously reduced; and it seems lots lighter.
    The kicker, the HJC, because there is so much space between my cheeks and the helment, seems less safe. (Don't get me wrong, it still passes all the helmet-fitting tests. It just doesn't hug my cheeks and I've grown accustomed to that with the Scorpion.)
    I just wanted to say something about this because I have talked with some guys and read about others who feel the need to bump up a size with Scorpion. I wanted to say that if you can get used to your head being "hugged" then bumping up might not be necessary. Your mileage may vary.
    ScooterDog
    Site Elder TheOne's Avatar
    Oct 2006
    Houston, TX
    660
    You could always take out the cheek pads and set some book on them overnight, that will make them compress a little.
    Snug is better.
    2003 Z1000 Mods (Totalled out):
    Corbin Seat, K&N, Modified Air box, Zero Gravity Screen, Fender Eliminator Kit, Shotgun Frame Sliders, Spiegler Black Stainless Braided Lines, 2002 ZX9R Header, Yoshimura Slip On, Power Commander USBIII
    New: 2003 Z1000
    Full System - Muzzy Header, Devil Carbon Can
    Galfer Braided Lines- Front & Rear
    636 Rear Shock
    ASV Levers
    Fender Eliminator
    Intergraded Signals
    Air Box Mod
    K&N
    Custom Seat
    Ride Safe & Wear Your LID!!!
    Sep 2003
    Ottawa Canada
    2,109
    You can get different sized cheek pads for some HJC helmets too.
    Rising Star Wildcat's Avatar
    Athens, GA
    486
    My wife would second these thoughts. When trying them on, she didn't even try the small (the size she ended up getting) at first because the cheek pads are really snug when putting on the lid. I urged her to go ahead and pry it on. After getting it mounted, she decided it was the size she needed. Being a cruiser rider ('03 Shadow Spirit 750) she was reluctant to get a full face. Now that she has had it for 4-5 months, she won't EVER go back; she <3 it. Also noted is that it is fairly quiet, probably due to the tighter cheek pads that kep the under helmet air to a minimum. I know that when I am up for a new lid, while I really like my AGV, a Scorpion will be the first I try out.
    "I don't like repeat offenders, I like dead offenders."
    -The Nuge
    http://www.youtube.com/watch?v=T_QjEL0uUgo
    Supreme Being scrubdog24's Avatar
    Mar 2005
    Wilmington, NC
    39
    1,323
    When I first tried on my AGV helmet it was the same deal, I thought holy cow this is tight, but it was a GOOD tight. I rode a couple months and didn't think the cheek pads would compress either, but now they are conformed to my face and it's still tight. I've heard only good things about Scorpion.
    Current Bike: 2003 Yamaha R6
    Mods:Fender Eliminator, Short Stalk Signals Front and Rear, Shogun Frame Sliders, Swingarm Spools, ASV Levers, Jardine RT-1 Slip-on, K&N Air Filter, PC III USB, Factory Superflare Velocity Stacks, Galfer SS Brake Lines, Speedbleeders, Zero Gravity Double Bubble
    Supreme Being skorpyo's Avatar
    Mar 2007
    Florida
    1,337
    I ran into the same problem with the HJC the pads at first kinda huged my cheeks but after awhile they didn't. I didn't mind it much but when it's time to step it up and hit some speeds the helmet giggles cause there not squezzing the cheeks.
    I'm told diff helmets have diff fits and ofcourse all people have diff head shapes so I'll just go from shop to shop trying diff helmets on till I run into one that meets my demands.
    1990 red convertable mustang GT 5.0
    2003 orange Z1000
    https://fbcdn-sphotos-a.akamaihd.net..._7692724_n.jpg
how tight cheek pads helmet
how to make a helmet less tight in the cheeks
modify scorpion helmet pads
scorpion helments to tight
scorpion helmet fits tight
scorpion helmet that is tight
scorpion helmet tight
scorpion helmet tight cheeks
scorpion helmets tight
scorpion motorcycle helmet tight
