Honda Magna v45 problem electrical....
This is a discussion on Honda Magna v45 problem electrical.... within the Other Bikes forums, part of the General Forums category; hi there i have probleme with my honda 83 v45 ...when i turn the switch ON nothing work.. whit full charged baterie...so i have put ...
    Newbie Dr_xXx's Avatar
    May 2016
    hi there i have probleme with my honda 83 v45 ...when i turn the switch ON nothing work.. whit full charged baterie...so i have put multimeter on the baterrie to see whats going on...and the screen say 1.6 volt....what is the possibility of probleme ? short wire maybe ? directly to the batterie i have 30Amp fuse and 1 of the ruber cover have burning (overheating)...
    thanks you
    May 2016
    you can see the red wire burned....and when im deconecting de plug....the batterie stay at 12volt on the multimeter
    May 2016
    with wiring diagram i have identify the wire of the starter relay....
    the overheated wire on the picture is
    Red/White --- regulator
    Red --- ignition switch and main relay
    Yellow/Red --- switch / engine stop
    Green/Red --- clutch switch
honda v45 magna problems
