Fork oil for Yamaha XJR1300?
This is a discussion on Fork oil for Yamaha XJR1300? within the Other Bikes forums, part of the General Forums category; Hi guys looking for some oil for my XJR1300 does anybody know a good place to purchase and also what grade oil? Many thanks!...
Results 1 to 4 of 4
    Newbie racer30's Avatar
    Oct 2014
    Lincolnshire
    Many thanks!
    Oct 2014
    Lincolnshire
    Hi Guts,
    Spoke to Brook Suspension this morning regards to fork oil and they recommended Fork Oil - Suspension Fluid - 5W - 7.5W - 10W - 15W I Motul 10W Grade. Does anybody recommend any different for any reason, if not im going to order later today.
    Thanks.
    4,295
    870 times
    I bought Lucas synthetic fork oil for mine. Synthetic Fork Oil
    Can't recall if it was 10w or 15w.
    The amount you need and choice of weight will vary depending on what your bike specifies.
    I would assume any fork oil will work. The higher the weight the stiffer they will be.
    Mar 2004
    Delaware
    1,021
    33 times
    What Obo said. Unless you're racing, any brand-name fluid should work fine. Some folks claim fork oil is just ATF; no clue if that's true but it smells and feels similar. A few years ago I bought a Motion-Pro tool (http://www.amazon.com/Motion-Pro-08-.../dp/B000GZPCYI) to get the oil levels as exact as possible, but for many years before that I got away with simply using a measuring cup, without ill effects.
    2015 Versys 650 ABS
    (Former owner 2003 ZR-7S)
    ZR7OA No. 984
    AMA, Retreads Int'l.
    Mods/Farkles: Puig "Touring" windscreen, Givi V-47 top case, SW-Motech gas cap mount tankbag, Givi hand guards, BMW Sport Grips, Omni-Cruise throttle lock, Motowerks mirror extenders, Denali Mini Soundbomb horn, Mag-Knight tank pad, decalectomy
