Well, I thought about it for a moment - Page 2
This is a discussion on Well, I thought about it for a moment within the Ninja H2 forums, part of the Kawasaki Ninja H2 category; I will break it down for you. You know how you have the yellow speed signs on the road....and also the white ones? It's the ...
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Like Tree3Likes
Thread: Well, I thought about it for a moment
    Feb 2014
    Yukon, Ok
    2,998
    908 times
    I will break it down for you. You know how you have the yellow speed signs on the road....and also the white ones? It's the same thing. Yellow is the recommended limit...white is the true and absolute limit.
  2. #17
    8,494
    1496 times
    hbk, it it were an issue, a problem, or worth mentioning, I don't believe Ive ever seen a couple , riding on a Harley, that would be within a limit. Ive seen many where rider weight went well over 500, and we wont even mention accessories or gear.
    Sorry...ive got to go back to my manual to look up my concours 14s towning limit. Ive not found it yet.
  3. #18
    Supreme Being DaddyFlip's Avatar
    Sep 2013
    SEARK
    47
    2,091
    402 times
    Your margin of safety increases exponentially, well maybe geometrically; actually infinitely if you remove the swingarm (since you can't go anywhere). I guess there's still the danger of your dropping it on yourself due to poor balance.
    But yes, shave 10 pounds here, add 10 pounds there.
    2001 ZR-7s (ZR750H1).....R.... "Ol' Red"
    1995 FXDWG Dyna Wide Glide "Grunt Pig DhaWG"
    Sep 2013
    SEARK
    47
    2,091
    402 times
    I CANNOT STOP LAUGHING AND CRYING! Best single line in an H2 review I've read!
    On a full throttle, it picks up smoothly from as low as 2500 rpm, and delivers you a predictable build of power through the lower midrange. By the time you hit 7,000 rpm, it's whipping itself into a furious lather, and up between 10,000 rpm and the 14,000 rpm redline, there's nothing to do but hang on with every muscle clenched, especially the circular ones, and listen to a full and fruity series of profanities leaving your body whether you want them to or not.
    Review: Kawasaki's supercharged H2 is an elegant artwork of supreme violence
  6. #20
    1,513
    513 times
    D.F., I disagree on your statement about the swingarm sticker. That "sticker" recommended tire pressure of a ZR7, (or a car for that matter) isn't always correct or gospel by any means. Consider the differences between the OEM bias ply tires it had when new, vs whatever radial tires and/or dual compounds which maybe on it now? Your tire pressure can/should change depending on the particular tires stated air pressure recommendation on the sidewall.
