Smallest battery for 2012+ 650
This is a discussion on Smallest battery for 2012+ 650 within the Ninja 650R Performance Upgrades forums, part of the Kawasaki Ninja 650R category; Trying to find the smallest battery needed to crank a 2012+ Ninja 650. Smallest as in volume. Also if anyone has the requirement for cranking ...
Results 1 to 2 of 2
    Site Elder Napkin Legend's Avatar
    Nov 2012
    Scurry, TX
    790
    129 times
    Trying to find the smallest battery needed to crank a 2012+ Ninja 650. Smallest as in volume. Also if anyone has the requirement for cranking amps. Only lighting on the bike is headlight and brake light, both LED. Gauges have been swapped to LED unit as well. Minimal electronics. Thanks.
    Sent from my SM-N920V using Tapatalk
    2013 Kawasaki Ninja 650
    ZX6r Front End
    Blue Ridge Performance 180 ZX6r Rear Wheel
    EBC Performance Clutch Springs
    -1 Front Sprocket
    Vortex Aluminum Rear Sprocket
    TechSpec Tank Pads
    Evotech Radiator Guard
    Venhill SS Brake Lines
    Short Levers
    Luimoto Seat Covers
    Kawasaki Seat Cowl
    Yoshimura Fender Eliminator
    Dominator Headlights
    Rising Star chdrummerdude's Avatar
    Jun 2014
    222
    47 times
    Get a lithium battery from advance auto. An LP-4 should be the part number. They're super small and weigh nothing.
    07 Ninja 650r
    custom shorty Muzzy slip on
    Sport Bars
    Zero Gravity Double Bubble Shorty
    EK gold & black Chain
    Ebay Short levers
    Morimoto mini H1 projectors
    Ebay Led Tailight
    Ermax undertail
    Puig wheel hugger
    Custom machined SS heavy bar ends 13oz Each
    PCV + Autotune
    Lithium Battery
