Lowering front end
Lowering front end
This is a discussion on Lowering front end within the Ninja 650R Performance Upgrades forums, part of the Kawasaki Ninja 650R category; Alright...I've tried searching for it on this forum and google, maybe I'm adding a crossed 't' or dotted 'i' when I'm not supposed to... I'm ...
Results 1 to 8 of 8
    Newbie AKNinja09's Avatar
    8
    Lowering front end
    I'm trying to find out how to lower the front suspension on my 09'. I'm hearing all the measurements needed for it but no actual procedure to do it.
    Any help would be appreciated.
    -Passion Red 09' 650R: SM Sport Bars, Two Bros V.A.L.E. slip-on, 'custom smoked' windscreen, 250R mirrors, Gray Rearsets(Like the color clash), Targa Fender Eliminator Kit(LED)-
    Supreme Being unL33T's Avatar
    Feb 2009
    Toronto, Ontario, Canada
    1,325
    Haven't done it but I hear there are several methods.
    This is the only method I can recall from memory:
    Put the bike up on a rear stand and triple tree stand.
    Put a floor jack under the front tire.
    Loosen the bolts clamping the triple tree to the forks.
    Jack up front tire until desired amount of fork tubes is extending above the triple trees.
    Measure how much is extending on both tubes and make sure it is even.
    Tighten down bolts.
    Take bike off stands.
    You're done.
    The other method I've read involves getting a buddy to help you hold up the bike while you loosen the triple tree bolts just enough to "walk" the bike down the forks a little. I don't fully remember the procedure to do this without dropping the bike though.
    2009 Candy Plasma Blue Ninja 650R (has a cup holder)|Mods: Passenger foot peg flip up cup holder; ER6N grab bars; Grab bar sliders; Woodcraft swingarm spools; '09 fairing vibe fix; Thick weather stripping under seat; SportBars; Ninja650Shop.com no-cut sliders.|Upcoming: Fork sliders; Extended swingarm spools; Bar-end mirrors; HIDs with projectors.
    1987 Guard's Red Porsche 944 N/A (no cup holder)|Stock.
    Rising Star Lib'in's Avatar
    Nov 2009
    Pacifc Northwest
    254
    More simpler than what unL33T posted, also if you don't have a rear stand
    Follow these direction's, scroll down to page 5 and 6. Shows you exactlly how to do it safely, one side at a time.
    http://motowerk.com/Documents/Kawasa...structions.pdf
    This method worked great for lowering the front on mine.
    2009 Ninja 650 GREEN
    8
    thanks guys! I'll see what looks easiest to do in my garage:P and then hope the snow disappears!
    Up-And Comer flyboy9's Avatar
    Calgary, AB Canada
    29
    30
    its nice how we dont need to buy anything to do this mod, I like free things
    2009 Blue Kawasaki Ninja 650r
    Mods so far: Sport bars, Progrip hand grips, Blue angel eye projectors w/ 6000k HIDs, Blue LED caution lights, Black Arrow slip on, Ermax rear seat cowl, 12V power oulet, Ram mount to hold Garmin 1350 GPS, Fender eliminator, Blue underglow, Clear Alternatives tail light
    To install: Blue wheel stripes, NinjaShop No-cut Frame sliders
    Rising Star donovan's Avatar
    Mar 2010
    NH, USA
    171
    This looks easy per that pdf. Would this only be done in conjunction with the rear, or is there some benefit to lowering just the front? How does it change the handling characteristics?
    Up-And Comer Ptwin07's Avatar
    Apr 2009
    its very easy.
    2007 Kawasaki 650R
    Arrow slip on
    Power Commander
    Zero Gravity double bubble wind screen
    Pipercross filter
    TC2 170 rear tire
    OEM seat cowl
    Vortex rear spools
    Vortex front -1
    Vortex rear sprocket
    Driven clip ons
    Air box mod
    and then I ran outa money lol
    Newbie dark knight's Avatar
    May 2010
    San Jose, ca
    22
    Quote Originally Posted by flyboy9 View Post
    I have a question where did you get the headlight bulbs for your 09 ninja I want the same blue bulbs. and what size to get?
    ninja 650r metalic diablo ermax seat cowl sport bars
650r lower front end
how to lower 09 650r
kawasaki ninja 650r lowering front end
lower a ninja 650r
lower front ninja 650r
lower ninja 650r front suspension
lowering front suspension on 650r
lowering ninja 650r front end
ninja 650r lower front
ninja 650r lower front end
