Upgrading front brakes..
This is a discussion on Upgrading front brakes.. within the Ninja 650R Performance Upgrades forums, part of the Kawasaki Ninja 650R category; Hey guys, I'm thinking about upgrading the front brakes. By that, I mean just changing pads and lines, not calipers. Wanted to know if any ...
Results 1 to 11 of 11
    Rising Star greykawi's Avatar
    May 2009
    Suwanee, GA
    229
    Hey guys, I'm thinking about upgrading the front brakes. By that, I mean just changing pads and lines, not calipers. Wanted to know if any of you have tried steel braided lines. BRP has some and I also wanted to know if their $85 Vesrah brake pads are worth the $85. They also have some EBC's for $70. What differences would I expect to see if I upgraded to steel braided lines? Input would be much appreciated. Thanks.
    Supreme Being KDOG's Avatar
    Jul 2006
    Lemoore, CA
    1,207
    Quote Originally Posted by greykawi View Post
    I have Goodridge front and rear steel braided brake lines. I bought my rear from Gary at BRP. You can expect a quicker stopping bike. There was a slight delay with the stock lines especially when it was warm.
    DynoJet Power Commander (PC3), Arrow Aluminum Exhaust, ProGrip Tank Protector, ZG Double Bubble Short Screen, Piper-Cross High Flow Air Filter, Vortex Swing Arm Spools, Michelin Pilot Powers 170/60 ZR17 - rear, 120/70 ZR17 - front, EK RED 520 chain, Goodridge front and rear steel braided brake lines, R & G Frame Sliders, Ninja 650R Sport Bars version 1 bent and now version 2, Pro Grip 717 Sportbike Grips and Ninja 650R Billet handlebar clamp, JC Motors motorcycle cover, Woodcraft full rear sets.
    BRP
    BRP is offline
    Supreme Being BRP's Avatar
    Nov 2005
    North Carolina
    2,635
    EBC-HH pads are good for all around riding.
    Vesrah RJL pads are for racing/track day use, or performance style riding.
    Vesrah's have better initial bite.
    EBC is also makes an new pad Extreme Pro, which we will be using next season.
    For the 650, these retail for $75 a side.
    I'll have them on my site soon.
    http://www.ebcbrakes.com/motorcycle_...reme-pro.shtml
    Up-And Comer ballisticexchri's Avatar
    Dec 2006
    50
    Stock Kawasaki pads and steel braided lines. Motul 800 brake fluid. After bleeding brakes, hold lever in overnight with zip tie. Your brakes will be rock solid hard the next day.
    I stay away from aftermarket pads. I have yet to find an aftermarket pad that will outperform the stock ones.
    I am by no means putting down aftermarket. I just like the overall feel and performance of stock pads.
    BRP
    BRP is offline
    Nov 2005
    North Carolina
    2,635
    Quote Originally Posted by ballisticexchri View Post
    That's a good start. Have you ever tried back to back tests? I have, and the OEM pad to hold a candle to Vesrah's.
    I have not had a chance to try the ECB Pro's, but my riders have, and like them
    over the Vesrah's.
    Up-And Comer Acme Racer's Avatar
    76
    Quote Originally Posted by BRP View Post
    over the Vesrah's.
    Sorry to hijack the thread.
    Gary you say your riders like the EBC-Pro's over the Vesrah RJL's and this is on the stock calipers?
    At my last race (back in September) I put on a set of SRJL's on my R1 calipers (fitted to my 05zx6r forks) It is extreme braking. So much so that I have to be careful or I'll end up on my head. I'd call it overkill, and they weren't cheap.
    They'll probably last me all next year, but I'm always interested in input.
    I had a set of EBC's for part of the 08 season, and they warped after 2 race weekends, not OK.
    Dec 2006
    50
    over the Vesrah's.
    To be honest, no I have not run back to back tests. I have used EBC, DP, Moose Ceramic Backed, and SBS in the past.
    What I have found with aftermarket brakes is either grabby brakes with accelerated rotor/pad wear, weak brakes with long wear, or squeaky squealing brakes.
    I have never had an issue with stock pads. They always feel the same and wear the same each and every time.....
    I don't ride track so I cannot comment on how the stock ones would hold up in the "heat of usage".
    May 2009
    Suwanee, GA
    229
    Thanks. A friend of mine also said that, to just use Motul brake fluid and steel braided lines. Think I will go with that, since the aftermarket pads go for 70-80 dollars a side, expensive for me. Thanks again.
    BRP
    BRP is offline
    Nov 2005
    North Carolina
    2,635
    Quote Originally Posted by Acme Racer View Post
    That was the problem I had with EBC's in the past.
    The current HH's are supposed to be better.Problem was with the backing plate.
    We ran the SRJL's on our SV, with a GSXR front end. Yup, overkill.
    BRP
    BRP is offline
    Nov 2005
    North Carolina
    2,635
    Chris, we've been running the same rotors for 3 years, using Vesrah RJL's.
    Dec 2006
    50
    Wow! That's very cool! Especially since your point of view is from an "on the track" standpoint where the use is way more extreme than street use.
    Very good life of rotors indeed.
650r rjl
change front brake pads on ninja 650r
change front brakes ninja 650r
kawasaki ninja with vesrah brake pad
vesrah 650r
vesrah rjl or srjl
