How to Drain/Change Coolant?
This is a discussion on How to Drain/Change Coolant? within the Ninja 650R Maintenance forums, part of the Kawasaki Ninja 650R category; Hi I been looking through my manual but there is no clear instructions on how to drain the old coolant and add new one. Or ...
Results 1 to 9 of 9
    Newbie 2Fast's Avatar
    Jun 2012
    10
    Hi
    I been looking through my manual but there is no clear instructions on how to drain the old coolant and add new one. Or how many liters. Does anyone have a link to how to do it and what I will need? How often should it be changed?
    Thanks
    Supreme Being Smash's Avatar
    Denver, CO
    6,805
    700 times
    Your manual will tell you how often to change the coolant (look at the maintenance chart) and the coolant capacity. I also followed the manual's instructions when I changed the coolant last year.
    Supreme Being djrussell's Avatar
    savannah, ga
    2,579
    343 times
    The owner's manual doesn't tell you how. It just says "Have the coolant changed by an authorized Kawasaki dealer."
    There's a drain plug on the water pump. It's on the lower right side of the bike.
    Denver, CO
    6,805
    700 times
    Ah I see, I thought he was looking at the service manual. Hey 2fast, do you have a service manual? If not, what year is your bike?
    Rising Star chicagobob's Avatar
    Mar 2012
    West of Chicago, IL, USA
    318
    77 times
    It's in the service manual, under "periodic maintenance"
    Jun 2012
    10
    2007 Ninja 650r
    I do not own a service manual.. i only have a owners manual PDF since I didnt get a manual from the previous owner. Can I download a service manual somewhere?
    Denver, CO
    6,805
    700 times
    Mar 2012
    318
    77 times
    You can find a download on Google, but it's a pretty simple process to replace the coolant. The manual says to let the bike cool, then remove the appropriate fairing parts, remove and empty the overflow tank (temporarily hang it from the square hole in the radiator mount), remove the drain plug (on the side of the water pump housing), with a drain pan underneath, then remove the radiator cap (it has a two-step rim). When it has drained, replace the drain bolt gasket, torque the bolt to 87-in-lbs, mix 1.2 L of 50-50 water and aluminum-safe coolant, fill the radiator to the rim, tap the hoses to remove bubbles, install the cap, install the overflow tank and fill it to the "full" line, then check the level after the engine has warmed enough for the fan to run. If it's then below the "full" line, top it off.
    If it bubbles and overflows until the tank is empty, your radiator cap is probably bad, or the gasket or surface is dirty.
    Hope this helps.
    Jun 2012
    10
    Sweet thanks for the help guys Def. helps alot
changing antifreeze on a 2012 650 ninja
how to flush a radiator on ninja
how to flush radiator on my ninja 650r 2006
how to replace coolant in 650 ninja
ninja 650 coolant
ninja 650 coolant capacity
ninja 650 coolant flush
ninja 650r coolant change
replacment radiator cap ninja 650r
where is radiator in kawasaki ninja 650
