Hose size for brake bleed?
This is a discussion on Hose size for brake bleed? within the Ninja 650R Maintenance forums, part of the Kawasaki Ninja 650R category; What size tubing do I need to do a brake bleed? I'm going to try to install my SportBars tonight. Is there any type of ...
    Supreme Being unL33T's Avatar
    Feb 2009
    Toronto, Ontario, Canada
    1,325
    What size tubing do I need to do a brake bleed? I'm going to try to install my SportBars tonight. Is there any type of hose I should avoid (like that might be dissolved by brake fluid)?
    Thanks.
    2009 Candy Plasma Blue Ninja 650R (has a cup holder)|Mods: Passenger foot peg flip up cup holder; ER6N grab bars; Grab bar sliders; Woodcraft swingarm spools; '09 fairing vibe fix; Thick weather stripping under seat; SportBars; Ninja650Shop.com no-cut sliders.|Upcoming: Fork sliders; Extended swingarm spools; Bar-end mirrors; HIDs with projectors.
    1987 Guard's Red Porsche 944 N/A (no cup holder)|Stock.
    Rising Star snoborder42's Avatar
    Seattle, WA... Again...
    340
    39 times
    I actually just flushed out my brakes a couple of days ago... I used 3/16" clear flexible plastic tubing... Picked it up at a local hardware store for under $2.00...
    2006 650R
    R&G Sliders, Sport Bars, ZG Double Bubble, Comp Werkes exhaust, PCIII...
    Feb 2009
    1,325
    Quote Originally Posted by snoborder42 View Post
    Excellent! Exactly the info I needed.
brake bleeder hose size
brake bleeding hose size
hose size to bleed brakes
what size are brake bleader hoses
what size hose do i need to bleed brakes
what size hose for bleeding brakes
what size hose to bleed brakes
what size tube for brake bleeding
what size tubing is needed to bleed brakes
what size tubing to bleed motorcycle brakes
