how much and what kind of oil
This is a discussion on how much and what kind of oil within the Ninja 650R Maintenance forums, part of the Kawasaki Ninja 650R category; i recently had a mishap involving a stolen oil cap and massive amounts of oil leaking out of my bike. the cap is replaced, and ...
Results 1 to 11 of 11
    Up-And Comer knightrider's Avatar
    Oct 2006
    miami, fl
    70
    i recently had a mishap involving a stolen oil cap and massive amounts of oil leaking out of my bike. the cap is replaced, and i changed the oil to make ssure the theif didnt contaminate my oil as well. my question however is how much oil does our bike take? i put 2 quarts of 10w-40 synthetic mobil motorcycle oil. did i put enough, or should i add one more? i dont know how to read the oil window very well. i also noticed that my oil light never turns on even when starting the bike up since this happened which it used to turn on and stay on for a good 5-10 seconds when i first started the bike prior to this ordeal.
    any thoughts?
    Rising Star NoobCorpse's Avatar
    San Jose, CA
    367
    2 quarts of oil, 10w40 is the correct weight, but I've heard/read that you want to make sure you're using motorcycle oil and not auto oil.. I guess the difference is that the engine oil also serves the transmission, and car oil is not suited for this?
    Up-And Comer lumpia's Avatar
    Apr 2005
    Bay Area, CA
    37
    58
    MOM is your friend
    Up-And Comer deadsaxy1's Avatar
    Jan 2006
    Redding, CA
    30
    114
    It derpends on the vihicle... I had an old stick shift ford, and the motor oil served both engine and transmission in that... I'm not sure if its like that with all manual transmissions, but ive never heard anything about not using regular oil. I've been using castrol syntec since I bought the bike and havent had any issues with it...
    Up-And Comer Bryce's Avatar
    Feb 2006
    73
    Quote Originally Posted by deadsaxy1
    Don't use anything that has the energy conserving seal on it
    It has additives to make it extra slipery which will cause your clutch to slip.
    Best to consult your MOM (motorcylce owners manual) as it lists exact specifications to look for.
    There should be a label atck on your engine right by the oil check widow with capacities listed on it in Liters
    The Mobil Synth Motorcycle oil (MX4T I'm guessing is what you got) should be fine... Mine takes a bit more than 2qts, but I run a slightly larger filter and like to get my oil more towards the top of the full line than the bottom one.
    Bryce
    Oct 2006
    miami, fl
    70
    thanks for the replies everyone. the picture was especially helpful :-)
    May you never fall.
    May all cars watch for you and not you for them.
    May all the roads you ride be smooth and free of gravel.
    May all your riding days be filled with sun and no rain.
    Jan 2006
    Redding, CA
    30
    114
    so I'm assuming that castrol syntec has that energy conserving seal? I haven't had any problems with the clutch at all, so i think it's fine.
    Newbie BarryH's Avatar
    Nov 2006
    Kansas City
    60
    5
    motor oil
    The parts guy at the Kawi dealer told me that using synthetic oil like Mobil1 would damage the clutch, is that ttue or do they just want to sell me their oil. Really enjoying the forum, thanks for all the valueable info.
    Up-And Comer Kenneth Keene's Avatar
    Mar 2006
    Pennsylvania
    43
    Been using 10w-40 AMSOIL for a year. I have no clutch issues, and have about 7000 miles on it. Oil threads can go on for weeks, so be prepared. This thread could go on for a while!
    Supreme Being joshtex's Avatar
    Oct 2005
    Orlando, FL
    45
    1,386
    I used Shell Rotella 5w-40 Synthetic. It's deisel truck oil. Used it from 600 miles & did over 16,000 miles my first year. It helps reduce temps & makes the shifting smoother. Changed it every 4-5,000 miles. Also used Mobil 1 filters.
    Believe it or not there iis no difference between motorcycle oil & automobile oil. Check out this article about oil filters http://motorcycleinfo.calsci.com/Fil...tml#OilFilters
    Here is another one about oil. http://motorcycleinfo.calsci.com/Consumables.html#Oil
    Great site w/ lots of info
    Joshua
    R.I.P. GreenCheeze & RacerRaul
    '07 GSXR 1000 Flat Black & Orange
    Feb 2006
    73
    Quote Originally Posted by joshtex
    Joshua
    Except for the Energy Conserving Oils which have friction modifiers in it that will probably eventually make your clutch slip (first paragraph in the quoted article). Avoid those with the Energy Cinserving label...but the heavy truck oils like Rotella T are not EC oils and will probably do just fine. I run Rotella T dino oil in all my 4 stroke bikes/quads but my 650R which gets Mobil 1 MX4T.
    Bryce
how many quarts 09 ninja 650r
how much oil does a 99 kawasaki 600 hold
how much oil does a ninja 600 take
how much oil does my 2011 ninja650 take
how much oil is needed for ninja 650
ninja 600 oil
oil for a kawasaki ninja 600
oil for ninja 600
what kind of oil does a kawasaki ninja 600 take
what kind of oil goes in a ninja 650 r
