Flasher Relay help
Flasher Relay help
This is a discussion on Flasher Relay help within the Ninja 650R Accessories forums, part of the Kawasaki Ninja 650R category; I picked up a 2 prong, 12v flasher relay capable of handling 6 lamps at Autozone. No worky! LEDs went from fast flash to zero ...
Results 1 to 15 of 26
Thread: Flasher Relay help
    Supreme Being Smash's Avatar
    Denver, CO
    6,805
    700 times
    Flasher Relay help
    I picked up a 2 prong, 12v flasher relay capable of handling 6 lamps at Autozone. No worky! LEDs went from fast flash to zero flash. Indicator on dash is solid.
    Clearly the wrong flasher!
    Looks like I have to get one of the three prong ones, there were a bunch of options. Can someone help me choose the right one? Also, what should I be doing with the third lead off the relay?
    Denver, CO
    6,805
    700 times
    Just tried a 3 pin one marked "LED" and added a ground. Still no go! GRRRRRR. Gonna order a plug and play from superbrightled.com for $12 shipped and just be patient.
    EDIT: Clearly just talking to myself here... Move along folks... LOL
    Rising Star chicagobob's Avatar
    Mar 2012
    West of Chicago, IL, USA
    318
    77 times
    I used this $25 Amazon.com item that is a snap-in (fits the stock bike's wiring harness plug and mounting bracket), and is adjustable. Works great.
    See it at Amazon.com: 2-Pin LED Flasher Relay to Slow Signal for Kawasaki ZX6R, 636, Z750, Z1000, ZX12R, ZX10R, Ninja EX250, EX500 650R ZX7R ZX9R: Automotive
    Supreme Being djrussell's Avatar
    savannah, ga
    2,579
    343 times
    Are you using LED bulbs or just looking for a stock replacement?
    I don't think that polarity matters with a thermal flasher but if it does you want the X positive terminal to connect to your BR/Y wire and the L lamp terminal to connect to the O wire.
    You should only need 2 terminals so I think you're wasting energy with the 3 terminal one.
    Denver, CO
    6,805
    700 times
    Yeah, wasn't gonna spend that much dough on it though!
    Denver, CO
    6,805
    700 times
    Quote Originally Posted by djrussell View Post
    For LEDs. That's why I tried the 2 terminal one first.
    I maaaaaaaaaaay have had a snickers moment... I'm gonna try again a bit later with the 3 prong. Doesn't help that it's cold in the garage!
    savannah, ga
    2,579
    343 times
    I thiiiiiink this is the one you want.
    Novita/Heavy duty electronic flasher (EP37) | Flasher | AutoZone.com
    But for $20 (at least that's the price in my area) you'd come out cheaper at superbrightleds.
    Now I want a snickers.
    Denver, CO
    6,805
    700 times
    dj, my autozone didn't have that one in stock, or I certainly would've tried it!
    savannah, ga
    2,579
    343 times
    Go figure. Good luck sourcing one.
    Denver, CO
    6,805
    700 times
    Ah man. I'm an idiot!
    In more closely reading the packaging of the flasher I bought, it says "2 turn - 6 hazard." The relay itself says "2-6 bulbs." Well son of a... Sometimes I can't get out of my own way! Back to Autozone...
    Denver, CO
    6,805
    700 times
    Seems the Autozone next door doesn't carry any flasher relays that will handle 4 turn signals. Weird.
    Supreme Being Easy Rider's Avatar
    N. Central Florida
    3,123
    460 times
    Quote Originally Posted by Smash View Post
    First, you should get one with the same number of pins as the old one.
    Second, an LED counts for about a tenth of one bulb so if you have changed all 4 to LED, then your effective load is LESS than one bulb........and you need an electronic one
    that has set timing OR you need load resistors.
    Can't say more without knowing exactly what your setup is, that is the mix of stock and LED bulbs.
    Oh but wait.......I don't own a 650 so my advise is obviously useless.
    Bradmeister likes this.
    Denver, CO
    6,805
    700 times
    Edit. Not worth my time.
    Rising Star john doe's Avatar
    St Louis MO
    412
    119 times
    LF1-S-FLAT Universal Motorcycle Electronic Flasher | Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs
    That's the one I bought when I switched my turns to LED's. It plugged right in and worked. Just had to use a zip tie to hold it.
    My rides:
    2011 Ninja 650r burnt candy orange
    2012 Mazda 3 iTouring crystal pearl white
    2013 Lib Tech Jamie Lynn 157
    USD Carbon II olive green
    Denver, CO
    6,805
    700 times
    Thanks John, that's the one I referenced earlier. If I can't find a flasher locally tomorrow that works I'll order it. Of course I cut the wires off the OEM male plug too close to reuse. Drat.
12v flasher relay autozone
2 prong motorcycle led flash relay
ex250 flasher relay
klr 650 led flasher relay
klr650 flasher location
led flasher relay for ninja 636 2013
led flasher relay motorcycle autozone
ninja 650l flasher relay
novita ep34
would a ninja 650 flasher relay not make signals work
