Cigarette Lighter/Charger Question
This is a discussion on Cigarette Lighter/Charger Question within the Ninja 650R Accessories forums, part of the Kawasaki Ninja 650R category; So the PO wired one of those really cheap cigarette lighter/sockets or whatever you call them, under the seat wired into the left turn signal. ...
Newbie
So the PO wired one of those really cheap cigarette lighter/sockets or whatever you call them, under the seat wired into the left turn signal. He used those clamp on splicers that pinch the wire rather than cutting and splicing. --I think I'm explaining that right. Long story short, he said he blew up his phone charger because he thinks he reversed the wires during install.
The wires are both white, but anyone with a "little" bit of knowledge could have seen the faint writing on the negative side. I digress. So I put the wires into proper order and hooked up my GPS and all was fine. I will have to post pics of my custom GPS mount because it came out pretty slick, mounted right onto the middle of the handlebars.
The question is, how stupid was it to have it wired to the turn signal wire?? I left it, only because the wire damage has already been done (when I flipped the wires, I cut those of the charger).
If I go direct from the battery, how do you make it so it won't supply constant power?
07-01-12 10:19 AM
TC713
As long as there's nothing in the socket you won't be draining the battery or anything. If you want it to come on only when the bike is on you'd need to run a relay or hook it into the headlight circuit, etc.
Alternatively you could just have an on/off switch somewhere accessible.
p0diabl0
Wiring a relay to the plate lamp circuit should do the job. The socket could then be wired up to the battery, through the relay. Best include a fuse also.
http://www.morallyambiguous.net/
Current bike:
2009 Kawasaki ER-6n w/Bitubo Cartridge Fork Inserts, Hyperpro 3D shock, Kawasaki Windscreen, Givi V35 Saddlebags and E340 Topcase, Barkbuster Storm Handguards, R&G Radiator Guard
2012 kawasaki ninja 650 cigarette lighter
650r cigarette lighter
after i wire a cigarette llight socket to my motorcycle it shorts the gps charger
can i wire a phone charger to cigarettte lighter
cigarette lighter for motorcycle wiring
cigarette lighter instal sportbike
how to wire ninja 650 lighter
installing cigarette lighter on bike gps
installing cigarette lighter on bike gps to battery
installing lighter sportbike
ninja 300 cigarette lighter mount
what problem if i wire my cigerette lighter to my bike battery direct
wire cigarette lighter ninja 650r
wiring cigarette lighter motorcycle
wiring cigarette lighter socket motorcycle
