Running Zeros
Running Zeros
This is a discussion on Running Zeros within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; Hi Guys - Its been a while since I have been on here but still I'm riding my Meanie. My question is about riding the ...
Results 1 to 15 of 30
Like Tree10Likes
Thread: Running Zeros
    Up-And Comer Ponkster45's Avatar
    Apr 2014
    N E Scotland
    104
    82 times
    Running Zeros
    My question is about riding the Meanie with aftermarket filter and pipes with the fuel controller set at zero/ no fuel controller - I know a while back a number of people on the forum claimed to be doing this and I was wondering if that was still the case and if there had been any long term problems with doing it?
    I have had a PC III on my bike for a while which seems to make it run rich and not add much to performance , my insurance provider wants to load my premium for having one so I have decided to take it off as I don't think its adding anything- I'm just a little concerned it will run too lean.
    I don't have access to dynos so that is not an option ( If I did I would have tunes the PC III) and I do remember a number of folk on here talking about running zero.
    I am running a 360 K+N car filter( Cadman style) on the RH side (cross over removed) and cut down V&H longshots.
    Thanks for your help
    Ponkster (Chris)
    Apr 2014
    N E Scotland
    104
    82 times
    No one willing to offer an opinion ? Its not legally binding you know - I just remember lots of people in the past talking about zero setting on the PC III and wondered if they were still running zeros and the valves hadn't melted !
    Lots of views but no opinions it seems
    Up-And Comer T LON's Avatar
    Apr 2010
    san diego
    110
    32 times
    I run zero on the low end, just to get better mileage....u cant hurt it either way
    Up-And Comer jarmoke's Avatar
    Mar 2014
    Tampere, Finland
    86
    62 times
    Personally I have never understood that people are using PC III and running it with zero map - and then telling about the positive effects (one has better mileage, one has better throttle response, one has better acceleration etc.). I still cannot understand, because just using zero maps means that PC III is not changing anything in fuel map.
    If there are some other features which might be used while using zero map, then it should be definitely mentioned because it is totally different issue than "just using zero map".
    I do not mean to be rude or anything like that to anyone, I'm just wondering
    Up-And Comer EJay's Avatar
    Mar 2013
    104
    27 times
    Quote Originally Posted by Ponkster45 View Post
    Seven Exhaust Systems for Kawasaki Vulcan 1500 Mean Streak Motorcycle | Motorcycle Cruiser
    In the article you can read about the influence of different aftemarket exhaust systems on the AF ratio. I (we) don't know what your system is doing. Anyway - for tuning you would need the lambda readings.
    My Streak has a K&N air filter but stock pipes. I do not run a PC or fuel manager (= zero map) but rarely turn above 5000 and hardly need a high-speed enrichment the pipes mentioned above need. Indeed my Streak seems to run a bit lean up to 2400 rpm (IMO not due to the filter mod). To make a long story short: my valves have not melted yet.
    PS I'd rather be concerned about the pipes than the filter (as for lean condition).
    NEVER MIND THE BOLLOCKS HERE'S THE MeaN StrEAK
    Mar 2013
    104
    27 times
    Quote Originally Posted by jarmoke View Post
    My hundredth posting goes to......Jarmoke, Finland: You are not alone.
    The unmentioned feature is the accelerator pump function of the PC.
    jarmoke likes this.
    9,812
    2096 times
    I borrowed a pc3 once and put it on my Voyager. It tanked my fuel economy with no noticeable change in power or operating temperature. I returned it and now keep all my bikes stock.
    Rising Star skeptic's Avatar
    352
    100 times
    I borrowed a pc3 once and put it on my Voyager...I returned it and now keep all my bikes stock.
    That's probably best when you're clueless and have no skills.
    9,812
    2096 times
    Quote Originally Posted by skeptic View Post
    Love you too skeptic. Feel better now?
    1,518
    513 times
    "Best to have others suspect you an A-hole than open your mouth and prove it. or something like that I think? LOL
    352
    100 times
    Yep, every post of yours shows how true this is.
    1,518
    513 times
    Lets take a poll and the loser leaves the site...FOREVER
    HilbillyKat and hagger like this.
    Feb 2014
    Yukon, Ok
    2,999
    910 times
    Better that, than unwanted, unliked...and having sh** for a personality...like yourself sir!
    carryall likes this.
    Supreme Being madperson's Avatar
    Jan 2009
    Chesterfield, Virginia
    1,614
    715 times
    I've been running a zero map for about 3 years now, mainly because I'm to lazy to remove the PCIII, I am using the accelerator pump feature on it and that seems to make the initial deliver when I grab a handful of throttle a little quicker. I like many others, couldn't get it to quit running rich with the PCIII.
    Madperson (AKA Teddy Bear)
    2008 Mean Streak SE Memphis Shades Shield, MM angled risers, Leatherlyke Bags, Arlen Ness Rad 3 mirrors (black), Mapam forwards (black) with swing wing pegs, ISO flame grips with throttle boss, Hard Krome exhaust w/tips, Mustang Seat, PCIII, Spike Intake, luggage rack. 2 configurations when I'm done one as a solo, the other as a tourer.
    Apr 2014
    N E Scotland
    104
    82 times
    I didn't realise this was going to turn into a ***** Fest !
    I do know about the Accelerator Pump function - I was running it when I had the PC III connected.
    I also understand as with most bikes that one mode ( either pipes or air filter) doesn't need any fuel management - so I was most interested to hear from people running stock fuelling with aftermarket pipes and filters. I am running a pancake "spectra" filter (like a K+N) attached to the RH side into the throttle body and my pipes ate cut down Vance and Hinnes Long shots.
    I think I will be keeping the PCIII on ( putting it back on that is !!!) and turning down the fuel down a bit across the range - not exactly scientific I know - feel free to **** your pants about that but remember if your known to be a serial knob on this forum I probably wont be able to see your comments so save your bile for someone who gives a flying **** !
    To all the others who posted helpful comments - thanks , still seems a bit of debate on if we need a fuel controller but I guess slightly rich is a lot safer than running lean and hot on long runs.
