Handlebar risers (need to relocate cables?
This is a discussion on Handlebar risers (need to relocate cables? within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; Hi I been looking into handlebar risers and found some bad ace risers which were recommended by a few other ppl Handlebar Riser Extensions Kawasaki ...
Results 1 to 15 of 15
Like Tree5Likes
  • 1 Post By bearclaw
  • 1 Post By 04 Marauder
  • 1 Post By Bonequark
  • 2 Post By Donny J
Thread: Handlebar risers (need to relocate cables?
    Up-And Comer doh13's Avatar
    Jun 2016
    Canada
    74
    Hi I been looking into handlebar risers and found some bad ace risers which were recommended by a few other ppl Handlebar Riser Extensions Kawasaki Vulcan Mean Streak VN 1500 VN 1600 VN1600 | eBay My question would be if I install these 2 inch risers will I need to move or relocate any of the cabling?
    9,755
    2071 times
    Probably not, butt it depends. If the cables or wires are tight, you will have to relocate behind the steering head.
    Supreme Being bearclaw's Avatar
    Dec 2014
    Northwest corner CT
    38
    1,129
    963 times
    I just rerouted the front brake line through the tripple trees
    doh13 likes this.
    2015 Yamaha super tenere 1200 red
    2002 Red, Meanstreak 1500..... 20k ish miles
    Metzler roadtec z6 120/70/17 - 170/60/17
    Power commander 3
    Samson warlord long cannons, cut down 6/8"
    BadAce, symbiotic intake w/KN filter
    Mustang seat
    Vstream windshield
    MC Enterprises sissy bar
    Avon air heated grips
    BadAce cam tensioner extenders and reed block off plates
    Saddlemen saddlebags.
    Swingwings foot pegs
    All Balls, fork seals and head bearings
    Low and mean radiator shroud
    Jun 2016
    Canada
    74
    thanks for the info guys ill prob go ahead and order them
    Supreme Being 04 Marauder's Avatar
    Dec 2009
    Kentucky
    2,497
    1865 times
    Quote Originally Posted by bearclaw View Post
    Yep, I rerouted everything behind the triple tree. Best solution for risers.
    Steammaker likes this.
    I'm here cause I'm not all there!
    Low and Mean - Front fender, shroud, and final drive cover
    Bad Ace - Gusset covers, Risers, Triple Tree caps, and Reservior covers, Block off plates, Cam Chain tensioners
    Kuryaken - grips, stiletto end caps, and swing wing pegs
    1 1/4 bulls bars with risers
    Pro One diamond mirrors
    Corbin DT seat
    custom brake light and housing
    Mini LED Turn signals
    Vance and Hines big shots
    Woody intake mod
    Memphis Shades Pop Top with quick release braket
    Newbie Donny J's Avatar
    Jun 2012
    4
    I also have the 2" Bad Ace Risers for my Meanie. Need installation instructions. Thanks!
    Up-And Comer Bonequark's Avatar
    Jul 2016
    Manchester NH
    44
    43 times
    Donny, I just installed the Bad Ace risers. They are great for what they are and really simple to install. NO relocation of cables or anything is required. Just unbolt the handlebars from below and screw the risers into the bars. Then bolt the risers on to the triple tree. Done.
    Bad Ace made my riding position go from a pain to perfect in 10 minutes.
    bearclaw likes this.
    Jun 2012
    4
    Indeed. I put them on (WAAAY easier than I thought as (like u said) no need to re-route). while I really had no complaints about the original position, it is a FAR more comfortable and relaxed riding position than before. Thanks for your input!!
    Bonequark and bearclaw like this.
    Newbie mulefeathers's Avatar
    Jul 2016
    18
    Question about the risers. Are they threaded? I picked up a set that just had a through hole and the studs from the bars are too short.
    Jan 2007
    Sandbox
    3,791
    761 times
    Did you get universal ones? Sounds like you got the harley kind that would come with a longer bolt. Typically these have two mounting holes, one threads onto the original bar stud and then a bolt passes through from the bottom and threads/tightens into the riser.
    Although its been a while and I switched out the bars long ago so maybe I'm not remembering it right.
    Jul 2016
    18
    Yes they are universal 1.25 inches. I didn't realize the bars had studs till I removed them.
    Jan 2007
    Sandbox
    3,791
    761 times
    Yeah not gonna work then. There's still a few places that make them for our bikes. Not horribly expensive but definitely not as cheap as Chinese made universal Harley parts. Kewl metal, bad ace, and a few others
    Rising Star Aelwulf's Avatar
    Feb 2007
    Vandenberg AFB, CA
    251
    Refined Cycle has some as well, HR2s.
    Chat later, out ridin'.
    Vance & Hines Staggered Big Shots w/Jet Hot black ceramic coating; Mustang Vintage 2-up seat; U.S. Saddlebag Co. Flame saddle bags; Progressive fork springs; Clear Alternatives tail light; Black powder-coated rectifier mount (under radiator-eBay I think); Horizontal side-mount license plate holder with LED lights; Red brake/clutch levers (eBay); Red oil cap (eBay); Red mirror extenders (eBay); Dobeck EJK 3.0 fuel controller
    Newbie M. Streak's Avatar
    Mar 2016
    Houston, TX
    15
    I put the scootworks 2" ones on mine, pretty nice
    Newbie Shay's Avatar
    Mar 2017
    WI'll the risers fit a 2003 1500?
