My winter build project
This is a discussion on My winter build project within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; Doing a winter build bproject out the Marauder, including some maintanence upgrades, paint motor work and performance enhancers. Some of the parts are here and ...
Page 1 of 11 12345 ... LastLast
Results 1 to 15 of 164
Like Tree211Likes
Thread: My winter build project
    Supreme Being 04 Marauder's Avatar
    Dec 2009
    Kentucky
    2,497
    1865 times
    Doing a winter build bproject out the Marauder, including some maintanence upgrades, paint motor work and performance enhancers. Some of the parts are here and others are beginning to flow in, others have yet to be ordered, but it's early in the season and I probably won't get started on it until late February so lots of time to get exactly what I want.
    Parts on hand:
    Corbin Solo Seat
    Michelin Pilot 3 Tires in 120/70 front and 190/55 rear
    New three fin Cone breather
    Thunder 6 Spring clutch adapter
    Parts on order:
    Barnet Clutch plates
    Part s to be ordered:
    4.065 Forged Pistons and rings
    Dynatek wide band O2 sensor
    PCIII Fuel Processor
    DynoTune Dry NOS
    Top end Gasket set
    Machine Shop:
    Cam Grind
    Cylinder Honing
    Polish exhaust Ports and Combustion chambers
    Not complete but that's off the top of my head.
    lee, bearclaw, BlueFireAnt and 5 others like this.
    I'm here cause I'm not all there!
    Low and Mean - Front fender, shroud, and final drive cover
    Bad Ace - Gusset covers, Risers, Triple Tree caps, and Reservior covers, Block off plates, Cam Chain tensioners
    Kuryaken - grips, stiletto end caps, and swing wing pegs
    1 1/4 bulls bars with risers
    Pro One diamond mirrors
    Corbin DT seat
    custom brake light and housing
    Mini LED Turn signals
    Vance and Hines big shots
    Woody intake mod
    Memphis Shades Pop Top with quick release braket
    lee
    lee is offline
    Supreme Being lee's Avatar
    Dec 2011
    Lancaster, CA
    2,566
    1319 times
    Well, that should keep you busy and out of trouble for a while
    Dec 2009
    Kentucky
    2,497
    1865 times
    Lets hope so, the NOS is bonus power so that will be the last thing to be done this go around. I wanted to run twin 20oz bottles, but they're to big for the application so I'll go with twin 12's.
    Corbin DT seat
    Woody intake mod
    Supreme Being bearclaw's Avatar
    Dec 2014
    Northwest corner CT
    38
    1,150
    981 times
    Pics as you go!
    2015 Yamaha super tenere 1200 red
    2002 Red, Meanstreak 1500..... 20k ish miles
    Metzler roadtec z6 120/70/17 - 170/60/17
    Power commander 3
    Samson warlord long cannons, cut down 6/8"
    BadAce, symbiotic intake w/KN filter
    Mustang seat
    Vstream windshield
    MC Enterprises sissy bar
    Avon air heated grips
    BadAce cam tensioner extenders and reed block off plates
    Saddlemen saddlebags.
    Swingwings foot pegs
    All Balls, fork seals and head bearings
    Low and mean radiator shroud
    Supporting Member mcssls's Avatar
    Jun 2014
    Albuquerque
    644
    271 times
    You're not done yet?
    04 Marauder likes this.
    Custom paint 3.0, Bad Ace block offs, Bad Ace front turn signals. Ebay spike intake. Vance and Hines Big Shots. Demon Cycle DOT headlight with knockoff daymaker. No name LED rear turn, brake run. Mapam forwards, Mapam backrest. Factory Solo, shaved tail light, red LED under glow, brakeaway. 190/50r17 Shinko verge 2
    Rising Star Mstreak92109's Avatar
    Jan 2014
    San Diego, CA
    183
    58 times
    Put some work into a bowl blend then a 5 angle valve job. There is a lot of room for improvement there along with cutting down the valve guide since it also obstructs flow.
    Dec 2009
    Kentucky
    2,497
    1865 times
    I'll look at the bowl blend and assess it, but don't intend to make any mods to the intake side. Increasing the flow of the intake side reduces velocity and negativwly impacts mix. That effect has a negative impact on mid range torque. Sinc our bikes run at low rpm rev limits this is a big issue. Maintaining velocity on the intake side while maximizing flow on the exhaust side will maximize benefit on both ends, maintaining or improving mid range torque whil minimizing crank resistance from exhaust cycle.
    I'm not going super high compression as Colin did. My intent is about 11:1 compression with onboard instant power. I want the power when needed with a little more ban for my buck on pump fuel.
    Corbin DT seat
    Woody intake mod
    Jan 2014
    San Diego, CA
    183
    58 times
    You aught to buy one of David Wizard's books on porting heads, it will open your eyes to more than what you come up with on a simple google search. The main restriction in any head is/are the bowls, which will increase velocity as any bad angles will cause reversion and thus slowing your intake velocity. Also you need to know the rpm band you are working with for whether to put your attention to the top or bottom.
    Dec 2009
    Kentucky
    2,497
    1865 times
    I'll check it out.
    Corbin DT seat
    Woody intake mod
    Rising Star skeptic's Avatar
    351
    100 times
    Quote Originally Posted by 04 Marauder View Post
    Overly large exhausts hurt your power band just like overly large intake ports do. Normal "rule of thumb" on the flow bench is that the exhaust should flow 80% of intake. More on a nitrous motor if you're tuning for power on nitrous and willing to accept some loss when the nitrous isn't on.
    Dec 2009
    Kentucky
    2,497
    1865 times
    I've researching aero and Hydro dynamics the last couple days based on wing surface and smooth vs textured surfaces. more research to be done, but I'm considering a very specialized surfacing technique in the combustion chamber bowls. My goal is to increase flow and turbulence. the problem as I understand it is increasing flow at the expense of lost velocity negatively impacting mix turbulence. I still plan to polish the exhaust ports. I agree the 5 angle valve work is a very possible mod for this project.Well see this whole thing is developing.
    Corbin DT seat
    Woody intake mod
    Supporting Member Diamond Jim's Avatar
    Nov 2012
    Heart of Dixie
    2,795
    2465 times
    Just how fast do you need to go when passing that castle on Versailles Rd?
    Dec 2009
    Kentucky
    2,497
    1865 times
    Quote Originally Posted by Diamond Jim View Post
    Well..... as fast as possible I suppose.
    Corbin DT seat
    Woody intake mod
    Dec 2009
    Kentucky
    2,497
    1865 times
    I think I've located my pistons Forged flat top 4.04 dia. with 1.26 compresssion height. Not ideal, but the closest I've been able to locate. I wanted 1.20 compression height but can make this work with an adjustment to the bottom gasket, or a simple grind of about .03-.05". Still need to confirm the weight of the pistons and run some compression numbers, they should be a good fit to put me between 10.5 and 11.5:1 compression. Basically, with a OEM deck height of 1.1875 and the piston .045-.05 in the hole I'll be increasing piston surface lift .0275 out of the hole using OEM Gaskets on both ends, adding another .03 in compressed gasket materail on the bottomwill give me exactly what I'm looking for.
    I got the new air breather out tonight and checked it out. It's Sweet, but I need to Mod it to accept the temp sensor.
    I've reading a lot about adding NOS as it relates to compression. seems the rule of thumb is run low compression and compensate for the loss in natural HP with extra NOS. The proper set up however is managed in tuning on a motor with compression between 10:1 and 12.5:1. I personally dont believe in sacrificing natural power daily to make it up in 15 second bursts rarely so I'm going to run it right and tune it. Probably need to retard my timing about 4-8 degrees and run cooler plugs but it's worth it.
    bearclaw likes this.
    Corbin DT seat
    Woody intake mod
    Dec 2009
    Kentucky
    2,497
    1865 times
    Pistons ordered, I ended up going with the the 4.03 bore pistons in a 1.26 compression height, piston weight is 435 grams plus rings and and hardware. Decided a more conservative bore, even by .01" is a better option considering the increased pressures of NOS. Barnett Friction plates on the way, I'll order steels if I need them when I pull it apart. Intended to replace the friction plates either way.
    Can't wait until everything arrives, I'll be ready to get r done, and replace any necessities I find along the way. Being the Nitrous is bolt on for the most part I'll get everything built set up and tuned beforehand, and Add it last to the prepped system. Still need to acquire the wide band O2 sensor, but thats about it right now.
    Edit:
    Parts now on hand or in the pipeline-
    Corbin Solo Seat
    Michelin Pilot 3 120/70 and 190/55 tires
    Balancing Beads
    Intake breather
    Barnett Friction Plates
    .03125 compressed gasket material
    4.03 SBR Flat top Chevy Small block pistons
    6 Spring Clutch adapter
    Left to order-
    Dynotune NOS
    Dynotune O2 sensor
    Top end Gasket set
    Cooler plugs (8's or 9's)
    Corbin DT seat
    Woody intake mod
