Exhaust upgrade that doesn't rattle windows?
This is a discussion on Exhaust upgrade that doesn't rattle windows? within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; I saw a chart at some point that listed a bunch of exhausts and their rated decibel level, but I can't seem to find it ...
Results 1 to 15 of 16
    Newbie Mast3rshake's Avatar
    23
    I saw a chart at some point that listed a bunch of exhausts and their rated decibel level, but I can't seem to find it anymore. What's a suitable upgrade to the stock exhaust that won't **** off everyone in my apartment complex?
    Newbie jon_7687's Avatar
    I have V&H straight shots on mine. I wanted the same sound you're looking for. I took the stock baffle out and replaced with a non-straight through fiberglass wrapped baffle:
    Vance & Hines Straightshots Replacement Baffle - Cruiser Motorcycle - Motorcycle Superstore Its the top baffle in the pic.
    These were WAY too quiet, maybe a little louder than stock. So I took the cutting wheel to them and cut the capped end off, but left the fiberglass wrap. It sounds great now, at idle its tame but noticeable and under throttle its very aggressive. I'm sure that you would get similar results with any brand pipe and a baffle that was modded like this.
    5,805
    231 times
    Non Motorcyclist people tell me my BUB jugg Huggers are not obnoxious. They tell me they are actually louder at idle than they are at 2000 RPMs as I roll away from them. Of course they do bark at 5000 RPMs.
    Up-And Comer wineadors's Avatar
    May 2012
    Lewiston, Idaho
    75
    11 times
    You can always just de-baffle your stock exhaust. Takes about 20 minutes and has a great sound afterwards.
    Site Elder mean1's Avatar
    Jun 2007
    New Hampshire
    45
    659
    my friends bubs set off car alarms down town. When I had drilled stock pipes they were still very quiet IMO
    wicked bros 2 into 1 with hd wrap
    iso grips with throttle boss
    mustang seat
    PCIII
    thunder tornado
    Blacked out highway pegs
    16 inch ape hangers with 900 classic risers
    floorboards from a nomad
    ss throttle cables
    Arlen Ness tail dragger rear fender with plate holder stop blinker setup
    May 2012
    Lewiston, Idaho
    75
    11 times
    Quote Originally Posted by mean1 View Post
    I agree. I tried drilling my stock exhaust first. A little better, but not near enough. So I followed the tutorial and grabbed a 1 3/4" hole saw and about 15 minutes later had a much nicer sounding exhaust and retained the stock look.
    All that said and done however.......Bub JH's are on my short list.
    5,805
    231 times
    He must have taken the baffle out.
    Newbie patriotugcs's Avatar
    Aug 2012
    NC
    18
    I was thinking about taking the baffle out of my stock pipes as well. Where can I find the tutorial that you used?
    Supreme Being mike g's Avatar
    Jun 2007
    south of St. louis, MO
    33
    1,137
    the muzzy 2 into 1 with the baffle in is very mellow until you get on it hard. I can ease in and out of the subdivision at 5:00 am with no complaints, and my neighbors would let me know if it bothered them.
    2007 SE. Muzzy 2into1 exhaust, tornado intake, PC3, Custom sidemount w/ radiatnz led frame, clear alternatives integrated tailight, 1.25" bars, HEL black braided brake/clutch lines, iso grips with stilleto ends, corbin young guns/ dual tour seats, custom dynamics wrap around front turn signals. Lots of powder coated parts, Progressive front springs with 12.5 wt fork oil , and progressive 440 12.5" rear shocks.
    Rising Star wayne100's Avatar
    Nov 2005
    North Carolina
    329
    8 times
    Did it years ago, don't know where the tutoral is anymore. Basically you need a hole saw I think it was 2 1/4 inch( just measure inside the chrome) Get a dowel or just cut a piece off the end of a broom handle. Put that in a vise and using the hole saw, drill the center bit into the dowel, you don't have to go all the way in with the bit, it's just to locate the outer teeth of the bit, and keep it centered while you drill. Slide it into the hole in the muffler and the hole saw should land just inside the chrome and start drilling. If you already drilled holes around the edges this should go fast. Make sure the hole saw you use is for metal, not wood, or it will take a looong time and smoke your drill. Don't ask how I know that. Once you cut through that back plate grab a pair of pliers and twist it out of the way or off if you can get it. Then grab that center hole, thats actually the end of the baffle and just twist it back and forth till it brakes loose at the front and pull it out and you are done. Should look like this when you are done.
    I also gutted the cat at the same time so i don't know how much of a difference that makes. You can hear the bike coming now but not as loud as new pipes.
    05 Streak
    Mustang Studded Seat/Tank Pad/fender Bib
    Genmar Risers
    Mapam Forward Controls W/
    Dually Isopegs and heel rests/Brake/Shifter Pegs
    Isogrips w/ Dual Throttle Bosses
    and Stilletto endcaps
    Silver Bullet Driving Lights
    Sidemounted Plate w/Led Frame
    Brakeaway Throttle Lock
    Stebel Airhorn
    Bigshot Shield and Lowers
    Brakelight Flasher
    Homemade airkit(Looks stock)
    Resistor on Temp sensor
    Marbled
    Leatherlyke Bags
    Gutted pipes and cat
    Rising Star Redflash's Avatar
    Mar 2011
    Vacaville, Ca.
    267
    47 times
    Like the performance and sound of my Cobra 2 into 1 system....looks good too !
    Up-And Comer heston's Avatar
    May 2011
    Independence, Mo
    71
    My Bub JH are not what I would consider quiet at all. I do have the baffles in but quiet is not what they are. My friend has V&h bigshots and his are slightly louder than mine but not by much.
    Supreme Being speedracer's Avatar
    Jul 2007
    pickerington ohio
    1,819
    241 times
    Quote Originally Posted by wayne100 View Post
    Man i would like to hear those, you got a sound clip?
    04 vz1600
    ported heads
    10.8 CR
    cobra power pro 2 into 1
    power commander
    block off plates
    kuryakyn grips, mirrors
    jardine forward controls
    Jardine mini floor boards
    side plate mount
    vtx shocks
    spike air intake
    8 deg low and mean trees
    Jul 2007
    pickerington ohio
    1,819
    241 times
    Quote Originally Posted by Redflash View Post
    same here, on the cobra 2 into 1
    04 vz1600
    ported heads
    10.8 CR
    power commander
    block off plates
    side plate mount
    vtx shocks
    spike air intake
    Newbie droo_7's Avatar
    Aug 2012
    17
    Quote Originally Posted by speedracer View Post
    +1 .... Wayne100, are you able to provide a sound clip for your debaffled stock pipes? I don't mind the look at all of the stock pipes, so this looks a realistic decibel enhancer for me until i can afford to go after-market.
    2004 Marauder VZ1600
2004 kawasaki 1600 classic debaffle
cobra 2into1 exhaust
cutting exhaust pipe for louder exhaust
debaffle kawasaki exhaust mufflers
debaffle meanstreak
debaffling exhaust on meanstreak
decibel levels of performance mufflers
exhaust pipe
muffler rattles window
