210mm
This is a discussion on 210mm within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; Okay here it is. The cost of the wheel to get widened and shiped was $515.00 for me since I wanted a 7in wheel. I ...
Page 1 of 13 1234511 ... LastLast
Results 1 to 15 of 187
Thread: 210mm
    Rising Star MeanOneSIx's Avatar
    Nov 2005
    198
    210mm
    Okay here it is. The cost of the wheel to get widened and shiped was $515.00 for me since I wanted a 7in wheel. I went with 3/4in on the drive side and 1.25in on the brake side. Or you can do what Geo did and go for 3/4 on both sides. You have to completely diassemble the wheel prior to shipping it off to Kosman, bearings and all.
    While the wheel is gone this is the perfect time to start modding the swingarm. Simply disassemble the rear section and final drive. On the drive side of the swing arm you can leave the shaft in the housing and cut out a section and reweld a new piece on. You will have to do the welding with the shaft rod in the housing because after this mod is done you won't be able to remove the rod. Now what I did was create a trap door that was re-enforced so that I may remove the rod if neccessary. Sorry no pics of that process.
    Then once the wheel returns just reassemble and you're done. The reason for my bike being completely taken apart in these photos is because my brother repainted the tins for me. When you take the rear fender off be sure to shave the inner bracket down so that the new tire doesn't get cut whenever the shocks compress during a ride.
    One thing I have to say about the Titan. That ***** is BAAADDD! AZZZZ! She has a 107ci motor and will out run the Meanie everyday of the week. My brother Arnold pretty much built it himself.
    Rising Star SixFiveOh's Avatar
    Apr 2006
    Katy, TX
    56
    208
    Nice Job!
    Keith
    '06 Red/Black Suzuki Hayabusa
    '06 Black Kawasaki Mean Streak
    '06 Silver Kawasaki Ninja 650R - For Sale
    GEO
    GEO is offline
    Rising Star GEO's Avatar
    May 2007
    whittier,california
    237
    Hey MeanOneSIx! hope you don't mind but i added some color to the swingarm for better view, it might help the guys to get a better idea on how it will look once you cut the swingarm
    Nov 2005
    198
    No problem... I'll use your pics of the clearence to show how much you need to cut. Thanks...
    2003 and older models need to do this on the right side.
    Supreme Being Streaker's Avatar
    Apr 2006
    2,128
    Great Job explaining the process guys. So what your saying MeanOneSix is that it looks fine with just the weld and you don't absolutely have to chrome your rims. Right?
    So in all actuallity you could do the mod just for cost of having the rim widened plus cost of new bearings and a new rear tire.
    2006 Mean Streak
    http://www.meancycles.com/owners2/ho...0&OwnerID=1837
    List of Mods
    Vance & Hines Bigshots Exhaust, Thunder Mfg. Tornado Intake, Kuryakyn Wild Things TFI, 12" Smooth Ride Custom Chrome Shocks, Danny Gray Flame Seat, Reaper Front Fender, Radiator Chin Scoop, Front Axle Spikes, Rear Fender Spikes, Iso Grips with Spike ends, Kewl Metal Risers, Led Rear Turn Signals, Smoke Tail and Turn Signal Covers, Stebel Air Horn, Kuryakyn Retro Pegs, Arlen Ness Mirrors, Custom Jack Daniels Gauge Faces, Jack Daniels Air Cleaner Cover, Sidemount License Mount with LED, HotBox, Custom Mounted Softail Deluxe Hardbags
    Nov 2005
    198
    Quote Originally Posted by Streaker View Post
    YUP!
    Up-And Comer bigmeanie's Avatar
    Jul 2007
    DogHouse
    147
    Looks great with the fatty on there. Nice job MeanOne!
    2006 S/E Mean Streak
    Cobra Speedster Shorts Exhaust
    PCIII
    Baron's Big Air Kit
    Reed Block Off Plates
    Cobra License Plate Relocate
    LED Plate Bolts
    Kuryakyn ISO Grips
    Kuryakyn ISO Throttle Boss
    Kuryakyn Rider and Passenger Pegs
    Kuryakyn Shifter Cover
    Show Chrome Brake Pedal
    Kuryakyn Backrest
    Corbin Young Guns Seat
    Front and Rear Smoke Signal Lenses
    Smoke Tailight with LED
    Mods To Come
    New Front and Rear LED Turn Indicators
    LED Accessory Lighting
    Absolut Meanie:www.CruiserCustomizing.com/MeenStreak
    VROC #25081
    GEO
    GEO is offline
    May 2007
    whittier,california
    237
    For those of you that wonder what to use to cut the swingarm here is what i used a small dremel with small cutting wheels.
    GEO
    GEO is offline
    May 2007
    whittier,california
    237
    Me for example i didn't have to take the swingarm off or the fender to do the 210mm mod i just used a motorcycle jack.
    GEO
    GEO is offline
    May 2007
    whittier,california
    237
    because i whent only 3/4" on each side of the wheel kosman charge me $445 with shipping and the cost of my tire was $220 plus $30 in mounting and balance the tire,$30 for the dremel $10 for the cutting wheels that i used to cut the swingarm and $10 for welding wire my cost for the 210mm mod is $745
    You don't need to chrome the rims or polish them, i did because i get really cheap deals from these place were i always take wheels and motorcycle parts to have them chrome.
    Newbie flex67's Avatar
    Aug 2007
    swingarm ?
    I have an 04 streak and wanted to know if I still need to cut into the swingarm if I opt to go with a 200 series tire? By the way,nice bike.
    Nov 2005
    198
    Flex, mine is an 04 so yes you still have to cut and grind.
    Rising Star texas23's Avatar
    Magnolia
    339
    this is probably the most interesting and detailed thread I have seen on here. Thanks to all you guys for sharing the process. You have me thinking about putting that big tire on mine.
    Up-And Comer freightman's Avatar
    Apr 2007
    Jacksonville, Fla
    89
    Quote Originally Posted by GEO View Post
    I would like to see your bike when you get finished with the tire mod.
    GEO
    GEO is offline
    May 2007
    whittier,california
    237
    Quote Originally Posted by freightman View Post
    Hey freightman! my bike is done i got a few pics on the post your pic post but here a few more.
17 210mm rear tires
2003 kawasaki mean streak
200mm motorbike full fender
200mm motorcycle tire and 210mm motorcycle tire side by side
210mm kawasaki
210mm on softail
kawasaki mean streak fat tire kit
kawasaki mean streak wide tire kit
mean streak 210 rear tire
meanstreak dakota gauges
photos of 2007 kawasaki mean streak special edition
vulcan custom 210 rear rim
wide tire kit for kawasaki mean streak
