Biggest tire size
Biggest tire size
This is a discussion on Biggest tire size within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; My factory back tire is starting to get fairly bald and i wanted to replace it before i start the season. Does anyone know what ...
Results 1 to 14 of 14
    Up-And Comer 05hellbents's Avatar
    Apr 2007
    rochester
    30
    37
    Cool Biggest tire size
    My factory back tire is starting to get fairly bald and i wanted to replace it before i start the season. Does anyone know what the BIGGEST size tire i can fit on the factory rim and swing arm without altering anything, I was originally going to buy a warrior before i got this bike because i loved that fat back tire and if i could get a tire similiar to that on my mean streak, i would be so happy. any suggestions?
    Rising Star 02MeanieMan's Avatar
    Jan 2007
    C-town, O-H-I-O
    42
    477
    200 series is the biggest you can go without doing any mods to the rear end. Do a forum seach and you should be able to find previous posts about this subject
    2002 MEAN STREAK[/B]
    ~ V&H Longshots
    ~ PCIII(usb)
    ~ Custom Paint
    ~ Thunder Tornado Air Kit
    ~ Marauder headlight
    ~ 180/120 Metzler tires
    ~ Reed plates installed
    ~ Horzantal side mount plate
    ~ Debadged
    ~ Smoked lenses
    ~ Silverstar H4ST bulb
    ~ L&M Reaper Fender
    ~ L&M Radiator shroud/chin scoop
    ~ Lighted skull as engine cover
    ~ Lowered w/ VTX shocks
    ~ Chromed custom risers by meanmachinist
    ~ Danny Gray Raven Seat
    ~ Chrome Stock triple tree
    ~ Chrome inner engine cover
    ~ Progressive Fork Springs.....waaaay better than stock
    FUTURE MODS-
    Mapam Forward Controls??????
    Chromed wheels
    Up-And Comer jonailz's Avatar
    Feb 2007
    Detroit
    40
    82
    I stuffed a 200 Metz on mine on the stock rim....you have to loosen up the final drive to fit it in....but it will fit.
    Couple of cons though.....whatever shop you take it to do the work will whine and cry that they had a hard time getting it to fit (poor babies lol).
    And there is a slight difference in handling....seems like you'll have to lean just a little harder as you near peg-scraping cornering.
    Supreme Being troop's Avatar
    Oct 2003
    1,557
    Although a 190 or 200 can be pinched on, you are actually loosing contact patch to the roadway. The sidewalls have to be pinched so much that the contact area is rolled away from the road. A 180,although narrower, is probably the best compromise between appearance and function ....
    Thunder Tornado intake
    PCIII/Custom map
    Muzzy 2-1 meg exhaust
    Rising Star MeanOneSIx's Avatar
    Nov 2005
    198
    I have to agree with troop. 180mm is the best compromise to a fatter look than the 200mm tire, which on the stock rim, is no wider looking than the 180mm, and you won't give up anything in the handling dept.
    Up-And Comer Jbomb919's Avatar
    Dec 2005
    Michigan
    144
    The only thing you will be altering is the performance. The larger the tire size the farther down the performance drain you will be going.
    Nov 2005
    198
    Quote Originally Posted by Jbomb919
    Ahhhh I wouldn't say that. Yes the Mean Streak handles well but I felt like the tires were way to narrow for my taste. I modified my rear swingarm and wheel to accomodate a 210mm Metz and lowered the forks and this beast is right there in the handling dept. but hey that's my opinon.
    Dec 2005
    Michigan
    144
    Quote Originally Posted by MeanOneSIx
    Ahhhh I wouldn't say that. Yes the Mean Streak handles well but I felt like the tires were way to narrow for my taste. I modified my rear swingarm and wheel to accommodate a 210mm Metz and lowered the forks and this beast is right there in the handling dept. but hey that's my opinon.
    It is just my I am coming off of two naked bikes and I love the technology of motogp(That's why I hate nascar soooooo much.) So I am always thinking technology and performance first. Just a qwerk of mine. Its sad but I am trying to think of ways to make the meanie as light as possible. I need help LOL!!!!!!!
    All that matters is that you like it. If your on two wheels is all that matters.
    Nov 2005
    198
    I'm with you on the Moto GP thing. I also love F1 racing since it takes more skill to pass someone on a track that has multiple turns as apposed to just left. LOL I met a lot riders over the years but since being here in Germany I've got to say that Rossi is boss.
    Feb 2007
    Detroit
    40
    82
    I think that I would agree with you guys that I lost a little handling putting the 200 on the stock rim...it looks wider...but not enough. I need a wider rim to let the tire roll better. Question though....I've kinda been paying attention to what you have done to your wheel....and have looked into Kosman to do the same..do you think if I widened the rim, but stayed with the 200, I wouldn't have to bend the fender to clear the tire??...If not, and I have to mess with the fender anyway, I think I'm just going to get a set of chrome customs from RC Components...
    2005 Mean Streak
    PC III
    Hypercharger/Thunder Mfg. mount
    Kury turn signal mirrors
    Kury grips
    intergrated rear light/signals
    Progressive 12" lowering shocks
    Mapam forward controls
    Kewl metal risers
    Corbin saddle
    V&H Bigshots
    200 Metz
    Debadged
    Nov 2005
    198
    Staying with the 200mm vs the 210 means that you only have to widen the stock rim to 6.5 inches. That way you don't have to roll the fender nor would you have to shave the inner fender struts. Also you retain the stock mounting configuration without having to spend $1200-$1800 for an after market wheel. RC only makes a 5.5in wheel. and that means you'll still have a pinching problem with a 200mm. Kosman only charged $550.
    Feb 2007
    Detroit
    40
    82
    Cool.....I think thats the route I'm going to go. I was happy with the looks of the 200 before I had it crammed onto the rim.....I just want it to fit right...If I remember right Kosman is in Windsor....which is just over the bridge from me...I may just swing over by there and chat with those guys and see what they suggest as well..
    Thanks dude!
    2005 Mean Streak
    PC III
    Kury grips
    Kewl metal risers
    Corbin saddle
    V&H Bigshots
    200 Metz
    Debadged
    Newbie qdogg3's Avatar
    Apr 2007
    5
    MeanOneSix--What did you have do to the swingarm???
    2002 Mean Streak 1500
    Custom House of Color Marble Paint
    West Coast Choppers Fenders
    Progressive Suspension
    Custom Tank Work with aircraft style gas cap
    Billet Headlight
    Taillight frenched into rear fender
    LED Turn Signals F & R
    Thunder Air Intake
    PCIII
    Ness Teardrop Mirrors
    Corbin Young Guns Seat
    Custom Liscense Plate Mount with LED
    Chrome Switch Housings
    Custom levers
    Nov 2005
    198
    Pretty much you have to contour the shaft drive cover to clear the wider tire. I sectioned off a piece and made it into an access panel that I can remove whenever I need to maintainance it. If you do a search on here you will find the post of everything I did. Streaker posted it for me a while back.
02 vtx 1800c rear shock length
a 200 series tire rear swing arm for 2002 to rider
biggest rear tire mean streak
cani put 210 mm rear tire on a mean streak
how large a rear tire can i fit on 2005 mean streak
mean streak tire size
vtx 1800 c 200 back tire
vtx 1800 rear tire size
vtx 1800 wheel size
whars the widest tire u can put on 04 mean streak rear factory rim
