This broke off!!!!
This broke off!!!!
This is a discussion on This broke off!!!! within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; Whats up guys, so one of my pipes heatshields broke off the other day. well the little piece of metal that is welded on the ...
Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By foreman
  • 1 Post By HilbillyKat
Thread: This broke off!!!!
    Site Elder Nyinfamous2k2's Avatar
    Oct 2010
    NY
    909
    263 times
    This broke off!!!!
    Whats up guys, so one of my pipes heatshields broke off the other day. well the little piece of metal that is welded on the inside of the heatshield, that holds the metal clamp that goes around the pipe is what brok off. what do you guys recommend to get that little mount back on. I dont have a welder and I dont have a welding company near me to ask to tack it on. im thinking some kind of high heat epoxy. Ive used jbweld in the past with great success. but its only rated up to 300 dgrs, their high heat one only is good for up to 450 and their extreme heat (which would work, rated up to 2400 dgrs) ive seen a few videos of it failing from either not hardening or cracking. what do you guys recommend. thanks
    , 200/55 Avon cobra rear, 130/70 Avon storm front, sickle mirrors, ToyTech license plate mount, Progressive 444 shocks, spike intake, PC3, chrome spike grips, chrome bullet rear signals, chrome passanger pegs, chrome master cyl & brake res cover & switch housings, + other minor chrome parts. MassMax V-stream windshield.
    Site Elder foreman's Avatar
    Sep 2012
    Rochester
    834
    418 times
    JB weld is good stuff, i'm just worried about the vibrations. It may hold for a bit, but i fear the vibrating will cause it to crack and break off again. If i were you i would find someone within road trip distance that will weld it for you. JB weld in temporarily or even a big hose clamp to get you there. Have it done right. And you have a good excuse to go on a road trip
    B46 and Nyinfamous2k2 like this.
    2003 Meanstreak 1500
    Dark metallic purple
    Chuckster intake, Wieseco mapper,H/K Sideburners!
    Danny Gray seat, Avon spike cushion grips
    Cobra mini backrest
    Arlen Ness mirrors
    Low and Mean Reaper front fender and Chin scoop
    Progressive 440 12.5" shocks
    Oct 2010
    NY
    909
    263 times
    yea your definitely right about doing thing the "right" way. I just didnt know if there was some new product out that I wasnt aware of that might be made for this exact type of application. ill just have to find a spot to tack weld it back on for me .
    Newbie meatwagon's Avatar
    Jul 2016
    14
    High-heat JB weld worked for a few weeks - but vibration caused it to break loose. I ended up tach welding the tabs back on. However, this can (and most likely will) damage/burn/blue the chrome finish. I would suggest getting the heatshield as cold as possible (ice bath, or ice towel on the chome side) prior to tacking them back on. That's what I ended up doing on my V&H Big Shots
    Feb 2014
    Yukon, Ok
    3,050
    938 times
    You might want to give Quiksteel a shot. It's much more durable and heat resistant than JBWeld. https://www.walmart.com/ip/Blue-Magi...-2-oz/17134766
    My former boss and good friend used it to seal a hole in his case til the end of the cross country race season. He made the repair mid-race! It held together fine til he got time to replace the cases after the season. Afterwards, he carried it during every race in his tool pack...and swore by it!
    Nyinfamous2k2 likes this.
    Up-And Comer Risky's Avatar
    Jul 2013
    51
    8 times
    Just sharing my experience here
    I keep breaking these things too on my V&H big shots. Also the clamps themselves break regularly. And to top those problems off, my lower pipe is broken at the rear side of the powerport. I'm on my second set of V&H big shots with all the same problems. Just make sure you don't lose a heat shield on the highway and take out a buddy behind you. Also you might want to take a close look at the lower pipe where it is welded to the powerport. It can be completely broken but it won't fall off because one end is bolted to the head and the other to the rear exhaust hanger.
    I was on a road trip far from home with my buddies. I make them clean their bikes when we are at a motel, so we look *****in when we go to the local bar, but also it is a good way to find loose stuff on your bike. That is precisely what happened to one buddy when he was cleaning his bike...his heat shield came off in his hands...V&H of course. He finished our trip, but with the heat shield strapped to his rear rack. We got rid of his heat shields when we got home and put that pipe wrap stuff on, which worked really well and it looked wicked.
    I am going to try the Cobra Speedster's with powerport next. I know they sit a little closer to the ground on the Meanie, so I am just going to have to except that I will wear a flat spot on the lower pipe. I had Cobra on a previous bike and was impressed with fit, finish and sound.
    Good luck with whatever you do, and if you try to use that Blue Magic QuikSteel epoxy I would sure be interested in your results.
    Cheers all!
    Oct 2010
    NY
    909
    263 times
    Quote Originally Posted by meatwagon View Post
    that is something I was worried about also. my Brother just picked up a small cheap welder but we both have never tried it before. thats an option, maybe stick a ice pack or something under the spot we would tack it with. I just didnt want to experiment our first time using a welder with something on my bike
    Quote Originally Posted by HilbillyKat View Post
    Ok cool, ive never heard of that stuff. Ill look into it thanks. thats exactly the reason I posted this. maybe get a suggestion like this about a product ive never heard of. thank you
    Quote Originally Posted by Risky View Post
    Cheers all!
    for sure, always got to check for loose parts. I heard rattling on my way home from work, which is how I realized one of the 2 brackets broke off. when I got home I took the heatshield right off. been riding without it for the past week. no big deal. I actually thought about wrapping another set of pipes I had. Problem is from all my research I couldnt find a set of wraps that didnt either fade, discolor, or turn brittle within a yr. and just look bad after that. but that is an option also. ill have to see how wraps would look on these specific pipes. these are short straight pipes. Old picture but putting it up so you get an idea.
    [/URL]
    Thanks for all the suggestions guys.
