oil consumption
This is a discussion on oil consumption within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; i have had an oil consumption problem for a while now and it is driving me nuts. The compression on each cyl is in spec. ...
2Likes
oil consumption
i have had an oil consumption problem for a while now and it is driving me nuts. The compression on each cyl is in spec. 80 psi front and rear. it will use 1/3 of a qt. in about 300 miles. No smoke ( oil smoke ). The rear left spark plug looks like a run fat condition. So i got thinking that maybe the oil drain back screens are blocked off and not letting the oil drain back well enough and oil is getting sucked though the intake valve guide from being flooded with oil , so i changed the oil to a cheap dino oil with a cheapo filter. I added 2/3 of a qt of MMO and filled the rest of the way with oil. Now after about 150 miles all the plugs look great ( all the same dark grey ) and have not used any oil. So i am thinking this wonderful snake oil ( Marvel Mystery Oil ) may have cleaned out the oil return screens
04 vz1600
ported heads
10.8 CR
cobra power pro 2 into 1
power commander
block off plates
kuryakyn grips, mirrors
jardine forward controls
Jardine mini floor boards
side plate mount
vtx shocks
spike air intake
8 deg low and mean trees
07-20-12 08:05 AM
Very interesting indeed. Give us an update in a few hundred miles. I hope the improvement stays.
Phil - Southern Ontario, Canada
2003 Mean Streak
Muzzy 2 into 1
Chuckster Air Intake
PC III
47,000 km
Are you certain this is not attributed to the change of PC3 Map?
2007 Meanstreak 1600
Rasmith
nope even with the map i am using , it went through about 1/3 qt. of oil in about 250 miles or so. Only have rode about 150 miles give or take since the MMO, all looks good. Time will tell
04 vz1600
ported heads
10.8 CR
power commander
block off plates
side plate mount
vtx shocks
spike air intake
I can't think of how the map would have any effect on oil consumption.
2003 Mean Streak
Muzzy 2 into 1
PC III
47,000 km
I wasnt talking about the consumption..Just the fouled plug
Rasmith
plug really wasn't fouled, just was very dark and a little wet. we will see how it all goes in a few weeks of riding.
Bike ran great .
04 vz1600
ported heads
10.8 CR
power commander
block off plates
side plate mount
vtx shocks
spike air intake
Rasmith
Got it now. Sorry about that
2003 Mean Streak
Muzzy 2 into 1
PC III
47,000 km
va3ux
no worries
Rasmith
no worries
all seems to be good so far, plugs look great and no consumption ( oil that is )
04 vz1600
ported heads
10.8 CR
power commander
block off plates
side plate mount
vtx shocks
spike air intake
I need to perform some consumption..Week from hell at work here in Des Moines
Site Elder
Brat's and Cerveza! Mmmmmm!
Riding in honor of my Dad.
speedracer
Good ! And how many miles into the 'test' so far ?
2003 Mean Streak
Muzzy 2 into 1
PC III
47,000 km
So a different MAP remedied this issue right? Who woulda thunk it...
'03 1500 Meany "Red"
Cobra FI2000
Spike Intake
Samson Long's
Kury Iso. grips/pegs/pass pegs
Mustang seat w/Custom World backrest
River Road bags
Tank Bra w/Streak patch
Memphis Shade
Tombstone brake/turn
Axle mount license w/brake
chrome shaft/swingarm/radiator/clutch/brake levers/Free Spirit Master cyl. covers
Lindby guard w/highway pegs
Vista cruise
200/55mm Michelin rear
Reed plates
12" apes, 3"Risers & SS lines
Chrome WOLO Air Horn
No, the MAP had nothing to do with it. He ran a good dose of MMO in the crankcase and that seems to have done it.
2003 Mean Streak
Muzzy 2 into 1
PC III
47,000 km
2002 mean streak oil consumption
fuel comsumpion issues on 08 kawasaki mean streak
kawasaki mean streak oil consumption
no oil consumption after mmo
where is the oil screen on a 2002 kawasaki mean streak oil filter
