Lube levers?
This is a discussion on Lube levers? within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; Do you guys lube your brake and clutch levers? If so where do you apply the lube and what lube do you use? I was ...
Thread: Lube levers?
    Supreme Being jgrazjgraz's Avatar
    Sep 2008
    1,817
    39 times
    Lube levers?
    I was changing the number adjustment on my clutch lever and when I pushed the lever forward ,away from the grip to turn the dial, I noticed it was very tight,binding didn't spring back to 'at rest 'position.
    kury grips,throttle boss,cobra pipes,chrome radiator cover,kury helmet locks,kewl risers,kury dually pegs,ghost brackets w/kawi bags,chrome side covers and chrome foot pegs,leather tank bib,swing arm cover,l&r lower frame covers,chrome inner cover.Mustang seat w/backrest,tripple whammy,Kury cruise control
    Sep 2008
    1,817
    39 times
    Put a little white lithium grease. Worked it in. Much better now
    Jan 2007
    Sandbox
    2,955
    81 times
    Best way is to unbolt it, clean out road sludge, and put grease on before reassembly.
    07 Mean Streak SE; 07 Bandit 1250; 11 Camaro 2SS/RS M6
do you lube the lever
lube lever
lubing brake levers
lubing motorcycle clutch and brake levers
lubing motorcycle clutch lever
lubricate motorcycle clutch lever
lubricating brake and clutch levers
lubrication for motorcycle clutch lever lithium
recommended lube for brake and clutch levers
when to lube clutch lever
