what this noise
This is a discussion on what this noise within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; hello all can any of you possibly identify this noise cause it has me stumped. as soon as video starts you can hear it and ...
Results 1 to 9 of 9
Thread: what this noise
    Rising Star uriahk's Avatar
    Mar 2012
    northeast indiana
    246
    33 times
    what this noise
    hello all can any of you possibly identify this noise cause it has me stumped. as soon as video starts you can hear it and only lasts for a few seconds then quits. it was making noise before cam chain exts and stiil doin it after exts .any ideas thanks
    06 black and red.muzzy 2 into 1.caddman air filter,dobeck ejk 3.5,12" rise 1 1/4" drag bars, vtx shocks,lowered front fender
    mustang seat,vulcan classic backrest,fire and steel windshield,flyscreen,left side skull insert,relocated rectifier
    shinko ravens front/rear,throttle lock,ph customs tank bib w/pocket,imitation kuryaken grips w/throttle boss
    Site Elder rbthntr64's Avatar
    May 2010
    Show-Me State
    587
    Sounds like bearing chatter to me. Once oil gets to it, it quits.
    Riding in honor of my Dad.
    Supreme Being speedracer's Avatar
    Jul 2007
    pickerington ohio
    1,962
    291 times
    Quote Originally Posted by uriahk View Post
    if you start it with the clutch pulled does it do it? sound like a bearing to me as well, could be water pump.
    04 vz1600
    ported heads
    10.8 CR
    cobra power pro 2 into 1
    power commander
    block off plates
    kuryakyn grips, mirrors
    jardine forward controls
    Jardine mini floor boards
    side plate mount
    vtx shocks
    spike air intake
    8 deg low and mean trees
    Mar 2012
    northeast indiana
    246
    33 times
    Quote Originally Posted by speedracer View Post
    ill try it with clutch in but the other day i got about 250 feet downt the road and it did it i tried the clutch and shifting gears and it didnt stop it. do you think it something i should worry about
    Jul 2007
    pickerington ohio
    1,962
    291 times
    if you raise the RPM when it, does the pitch or volume change? Man not sure if you should worry or not. if it gets louder or something i would think yes.
    04 vz1600
    ported heads
    10.8 CR
    power commander
    block off plates
    side plate mount
    vtx shocks
    spike air intake
    May 2010
    Show-Me State
    587
    Anytime a bearing is chattering, it is cause for concern. It means the bearing is no longer effectively supporting because there is wear. Is it louder on the left or right side?
    Mar 2012
    northeast indiana
    246
    33 times
    i couldnt really pinpoint the location rpms didnt seem to affect the pitch. had it idle at aboout 1400 and sounded like it was from the front but then idled down to about 900 and sounded like the rear couldnt tell exactly where.it almost seemed louder from the right but i could still hear it from the left. i looked like an idiot running from side to side putting my ear to the engine lol. ill have to let it cool back down and see if it does this again i appreciate your guys help sucks that this is doin this it only has 11800 mile. i did just change the oil and there wasnt any metal on the screen
    Mar 2012
    northeast indiana
    246
    33 times
    ok think i got it i did the old wooden dowel rod to the ear trick. its coming from the right side front .the small clutch cover area .didnt get a chance to check bevel gear area thats the next place but that shouldnt be it cause that only operates if bike is in motion is that correct
    Jul 2007
    pickerington ohio
    1,962
    291 times
    water pump or oil pump maybe. I would maybe try a quick oil change, use 20w50 see what goes. I know you just changed it but maybe this may help you pin it down. Or flush the cooling system put water wetter with water back in. Water wetter will lubricate the water pump. Just a thought.
    04 vz1600
    ported heads
    10.8 CR
    power commander
    block off plates
    side plate mount
    vtx shocks
    spike air intake
clear alternative integrated vz1600
vz1600 cam chain noise
