ok so heres the problem i took the caps off the cam chain adjuster and measured the depth it was about a quarter of an inch. according to gadjets page its time for replacement is this correct? i have started hearing a strange noise just started recently it seems to be coming from front left not 100%sure when it starts making the noise its pitch stays the same ive pulled in the clutch and shiffted gears and that didnt affect the sound. rpm didnt seem to change the sound either from what i could tell i didnt have time to check into it this morning but when i shut it off the noise continued for a split second after. its not constant the noise does go away after a minute or two will try to get a sound clip if i can catch it. back to cam chain adjusters should they be replaced the bike only has 11500 mile on thats not normal is it. sorry for long post just got me bothered any input would be appreciated
LinkBack URL
About LinkBacks
