Completed this on my bike today but one thing I noticed I'm not sure about. When I removed the rear tensioner cap it was say 1/4 way or so full of oil, the front however was almost dry.....is this normal? Other than that everything went as planned.
This is a discussion on Question regarding Chain Tensioner Extenders within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; Completed this on my bike today but one thing I noticed I'm not sure about. When I removed the rear tensioner cap it was say ...
well, I thought a few people here had done this and could tell me if they had oil or not
When I removed the cap to check the extension, some oil came out when I checked the rear and none came out of the front.
I'm going to them this weekend so I'll know for sure.
Quick question: Did you use high heat red loctite to get it on to the rod?
I'm having trouble finding the high heat version locally.
ლ(ಠ益ಠლ)
I did use red loctite but not sure it was needed. I had some so I used it lol
Here is a answer I got in another fourm, makes sense: Front tensioner is angled down and will drain back in the tunnel, rear is just the opposite.
That would explain it. I checked mine this weekend (just ordered the extensions). I only checked the rear, found it about 1/4" in or so so didn't bother with the front. Yes, some oil poured out but since I didn't try the front I couldn't answer your question. Now I know for when I do the job.
Yes. I had a little oil in the rear cap and none in the front. All normal
Phil - Southern Ontario, Canada
2003 Mean Streak
Muzzy 2 into 1
Chuckster Air Intake
PC III
47,000 km
07 Mean Streak SE; 07 Bandit 1250; 11 Camaro 2SS/RS M6
04 vz1600
ported heads
10.8 CR
cobra power pro 2 into 1
power commander
block off plates
kuryakyn grips, mirrors
jardine forward controls
Jardine mini floor boards
side plate mount
vtx shocks
spike air intake
8 deg low and mean trees
04 vz1600
ported heads
10.8 CR
power commander
block off plates
side plate mount
vtx shocks
spike air intake
I wish I was back in NC. It's DC and its expensive, cramped, and too much traffic. Fingers crossed I can do the minimum 2 years and then get out of here. All I need in life is some space, a huge garage, and cold beer. DC only has the cold beer.
04 vz1600
ported heads
10.8 CR
power commander
block off plates
side plate mount
vtx shocks
spike air intake
Sorry for the delay. I have been in the hospital. I too had oil in the rear cylinder tensioner. Before I did the upgrade, I had them both out a couple of times. Each time it was the rear tensioner that had oil in it. It is a wet system so I do not think it anything to worry about.
Riding in honor of my Dad.
