Valve cover gasket
This is a discussion on Valve cover gasket within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; Anyone ever changes the valve cover gaskets on their bike. I was able to pin point the leak and its the second screw on the ...
Valve cover gasket
Anyone ever changes the valve cover gaskets on their bike. I was able to pin point the leak and its the second screw on the back cover that is leaking oil. Just wondering if its a real pain doesn't look like it would be to bad except for pulling the tank.
sent from my hand held computer
04-07-12 05:07 PM
The manual says to remove the engine but the oil is coming out from around one of the bolts it could just be the gasket on that bolt which is leaking I will try that first and then see what happens
keep us posted... fingers crossed
Tightened the bolt which would have been easier if I removed the tank but was able to get a little tighter. Rode around neighborhood and checked no oil as of now but we will see after a longer ride.
1500 vulcan leaking valve cover
how do i check valves on 1500 mean streak
kawasaki mean streak cylender gasket leak
kawasaki mean streak rocker cover
kawasaki mean streak valve cover seal
kawasaki meanstreet valve cover leaking
kawasaki vulcan oil leak valve cover
kawasaki vulcan valve cover oil leak
mean streak valve cover leak
meanstreak valve cover removal
remove valve cover kawasaki mean streak
va cover gasket
vlave cover gaskets on meanstreak
vulcan 1500 cam cover leak
vulcan 1500 valve cover leak
