Mean Streak - Bleeding Clutch/Brake Lines
This is a discussion on Mean Streak - Bleeding Clutch/Brake Lines within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; Hey, I'm in the process of changing the handlebars on my Mean Streak to some with a little higher set. I mounted the new set ...
Results 1 to 9 of 9
    Up-And Comer Keith Tobberman's Avatar
    Nov 2011
    71
    Hey,
    I'm in the process of changing the handlebars on my Mean Streak to some with a little higher set. I mounted the new set of bars, and flipped the old set upside down to get it out of the way. Now, I mounted the clutch side controls to the new bars, and my clutch lever has no resistance, so I'm assuming I will need to bleed the line. I will probably have to do the same with the front brake line. Is this a major flub up, or is it relatively easy to do this? I feel like an idiot for messing up, and I hope I didn't create a ton of work for myself.
    Thanks
    9,753
    2071 times
    What year is your bike and when was the last time you changed fluids? Should be done every two years. I use a vacuum pump from Harbor freight to do mine. Speedbleeders are nice to have as well. Just follow the instructions in the service manual and be very careful with the brake fluid. It will melt plastic and ruin other parts.
    Supreme Being jgrazjgraz's Avatar
    Sep 2008
    2,223
    217 times
    Check out this thread
    Clutch Fluid
    kury grips,throttle boss,cobra pipes,chrome radiator cover,kury helmet locks,kewl risers,kury dually pegs,ghost brackets w/kawi bags,chrome side covers and chrome foot pegs,leather tank bib,swing arm cover,l&r lower frame covers,chrome inner cover.Mustang seat w/backrest,tripple whammy,Kury cruise control
    Site Elder Boscoe's Avatar
    Mar 2011
    Missouri
    703
    202 times
    +1 on the vacuum pump. Does a great job on brakes and clutch. I used mine to suck the system dry and then to pull plenty of fresh DOT 4 through the system to flush it out. The brake calipers were full of all sorts of sludgy crap. To do both brakes and the clutch it probably took me about 30 minutes. Still looks fresh and clean after nearly two years!
    Nov 2011
    71
    Thanks for the replies. My bike is an '02. I have owned it for about half a year. The previous owner is a friend of mine, and owned it since new. I have no idea if he ever changed the fluid. Also, I had my fork seals replaced late last year. Would the clutch and brake have been bled then? Also, my front brake has a pulsing feeling, like a rotor is warped, but the mechanic said they're straight. Could this be because I need to do a brake flush?
    Thanks
    9,753
    2071 times
    You definitely need to flush out those lines. What color is the fluid? If you say anything but clear you need to flush out those lines. If you say root beer then let's just say buy a large jug of brake fluid.
    Rising Star Anthony's Avatar
    Jan 2011
    Land Of Enchantment
    210
    11 times
    Quote Originally Posted by Keith Tobberman View Post
    Hey,
    Thanks
    I bought this vacuum pump from Cycle Gear, on sale for $39.99. Very good quality.
    2007 Meanstreak 1600, 2007 Honda CBR600RR, 1997 Suzuki TL1000S
    Up-And Comer Finallymean's Avatar
    Oct 2008
    Columbus Ohio
    37
    114
    I replaced the stock lines with Braided stainless about 2 weeks ago. I purchased speed bleeders and the job was smooth. The front lines took about 45 minutes, to install the lines and then bleed everything. The rear was a little more time consuming. If you do the rear, make sure you get both bleeder valves. I bled the brakes on a sportster manually yesterday and the speed bleeders are well worth the money. It will cost ya about 30 bucks for the speedbleeders.
    02 Candy Gold Spark Meanie
    Hard Krome Stipper Straights
    Thunder MFG. Tornado Air Kit
    Power Commander III
    Kuryakyn ISO-Grips
    Kuryakyn Stiletto End Caps
    Kuryakyn ISO-Throttle Boss
    Kuryakyn Wide Style Levers
    Baron Custom Reed Valve Covers
    MBW Products Rear LED Turn Signal Assembly
    MBW Products Front Billet Wrap-Around LED Turn Signals
    LED Tail Light With Clear Lense
    License Plate Side-Mount Bracket
    Kuryakyn Stiletto Pegs
    Kuryakyn Brake Pedal Cover
    Kuryakyn Shift Lever Cover
    Kuryakyn Switch Covers
    VTX 1800 Shocks
    Stingerz White LED Accent Lights
    Nov 2011
    71
    Hey,
    Thanks again for the help. The brake does not need bleeding I guess, and the clutch seems fine. I pumped the clutch lever several times, and I could hear the air moving, and now it feel fine. I'll find out when I take the bike out for a ride.
    Thanks
bleeding o2 meanstreak clutch
brake fluid kawasaki mean streak
clutch bleed on 1600 mean streak
how to add break fluid to kawasaki mean streak
how to bleed brakes on 1997 tl1000s
hydraulic clutch fluid meanstreak
kawasaki mean streak clutch bleeding
mean streak brakes pulsating
meanstreak brake fluid
what is wrong with the clutch in my new kawasaki mean streak
