could be the gas then mixes with the old rubber hose that makes it look like oil..
This is a discussion on Stumped??? within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; could be the gas then mixes with the old rubber hose that makes it look like oil.....
kury grips,throttle boss,cobra pipes,chrome radiator cover,kury helmet locks,kewl risers,kury dually pegs,ghost brackets w/kawi bags,chrome side covers and chrome foot pegs,leather tank bib,swing arm cover,l&r lower frame covers,chrome inner cover.Mustang seat w/backrest,tripple whammy,Kury cruise control
I'm pretty sure it's not gas. As a matter of fact the spots in the driveway are still there. If it was gas, they would of dried up?? Actually now that I think about it, when I first noticed the spots, I dabbed them with a white napkin and it was a faint grayish....almost clear with no smell to it. Kind of reminded me of used gear oil without the distict odor. I guess after I looked up at that hose that was right beside the oil filter, I just assumed it was oil?? Now I'm not sure what the heck it is?? I really appreciate everyone's help but I'll report back with some pics or some better info when I do some more investigating. Thanks all!!
Cobra speedster slash-downs, cobra fi2000, Scootworks 1 3/4 riser ext. Kuryakyn iso-grips with stelletto ends and switch-blade driver pegs, smoked turn lenses, debadged, black alum skull rad cover, chrome switch cover housings, xenon gas H4 bulb, Kaw tank panel w/pocket, Kuryakyn brake pedal cover and shifter peg cover, K&N filter, chrome billet oval mirrors w/flames, LM chin spoiler, silver bullet rear turns relocated, horizontal side mount w/radiantz led plate frame, WCC front axle spike bolts, memphis shades del rey wind shield
Going back to good dino oil is not going to stop your oil leak, and why would you want to do that anyway.i would pull those hoses out from the location and move them somewhere else and see if the drops still are at that location or where you moved the hoses. Maybe you have some gear oil getting into the driveshaft tube and working its way up to the front u joint and leaking from the boot. just a thought.
04 vz1600
ported heads
10.8 CR
cobra power pro 2 into 1
power commander
block off plates
kuryakyn grips, mirrors
jardine forward controls
Jardine mini floor boards
side plate mount
vtx shocks
spike air intake
8 deg low and mean trees
I did get the cam seal to leak after I put synthetic in my 03 but cant say absolutely, for sure, that was the cause... some will say it though.
Well I took speedracer's advise and re-routed those hoses. Went for a ride, and found my leak.....apparently oil was leaking out around the seal of my walmart supertech oil filter...lol. and dripping onto that damn vent hose or whatever it is, making it look like the culprit!!! I gave it a snug turn with my oil filter wrench and went for another ride and no more oil!! Thanks speedracer and everyone else for the great advice!!!
Thanks to Rick for solving my leak to a T...LOL.
04 vz1600
ported heads
10.8 CR
power commander
block off plates
side plate mount
vtx shocks
spike air intake
Got back from a ride around 6pm today. Noticed oil all over my rear tire!! Looked underneath and sure enough....CRAP!!....oil on the filter again!!! I started to look really close all around the filter and couldn't find any oil at all! I started paying closer attention to where the oil was on the filter...1) it was in the middle 2) no oil whatsoever by the filter seal 3) no oil anywhere around this puddle??? WTF??? I then wiped everything clean and laid under the bike while it was running, didn't see anything. Rev'd her up a few times and sure enough the puddle of oil was in the same F*****G spot again!! Cleaned it up and had my son rev-up the bike while watching underneath.......guess what I saw???? A tiny microscopic hole smack dab in the very center of the filter, only leaking when putting a load on the motor!! No wonder this damn thing was so hard to find!! So my question is can I swap in a new filter without changing the oil?? If not, then I guess she's getting an oil change tomorrow!!
Just curious what brand of filter are you using. Seen this happen alot in the auto business and its not always a cheap filter either so Im not trying to bash your brand just curious which one. I happen to use carquest right now because I have an account with them and they carry the filter.
03 Mean Streak
Kuryakyn Iso Grips, Throttle Boss and Rear Pegs, CWI Highway Pegs & Sissy Bar & Luggage Rack, MS Big Shot Shield,
V&H Long Shots, Corbin Dual Tour Seat, Kuryakan Sound of Chrome Speakers and iPod Mount, Mapam Forward Controls, Brakeaway Throttle Lock, Chuckster Intake, Dobeck 3.5 module, Coaster Plates, HID Headlight, Saddleman Saddlebags with Easy Brackets, Kuryakyn GranTour Bag, Refined Cycle Risers and Mirror Extensions, Hotbox
