Engine knock is NOT normal!!
This is a discussion on Engine knock is NOT normal!! within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; My (purchased used) 02 mean streak with 15000 miles has had a noticable engine knock since I took off the loud pipes when I got ...
Results 1 to 15 of 19
    Up-And Comer 02 Streaker's Avatar
    55
    Exclamation Engine knock is NOT normal!!
    My (purchased used) 02 mean streak with 15000 miles has had a noticable engine knock since I took off the loud pipes when I got it just a month ago. Everybody seems to think this knock is normal for the Vulcan engine. After about 400 miles of listening to the abnormal knock I decided this weekend im going to find out if its normal. The engine is out and its comming apart! With the top end off to the cams I have already found something that could have destroyed the engine!! The KACR unit on the rear cam is falling apart! The limiting pin that stops the weights from flying out too far is almost torn out. You can see where the pin head has been hitting the rocker. I'm going down farther but i'm waiting on the tool to get out the sleeves around the spark plugs to get the heads and cylinders off. I want to check the bore size for piston slap. I'll keep you posted....
    55
    Got the bores off this evening and just as I thought the front cylinder has lots of piston scuffing on the front and rear face. The rear cylinder has some scuffing on the rear side only? Bores look like there is some wear but I don't have a bore mic and I cant get them measured till monday at the machinest. Kinda shocked at the amount of carbon builup on top of the pistons, seems excessive for an injected motor?? Previous owner could have run junk gas which could had caused the detonation that scuffed the bores? Either way looks like a rebore and new pistons and KACR units for the cams!
    Supreme Being troop's Avatar
    Oct 2003
    1,557
    Quote Originally Posted by 02 Streaker View Post
    Now's the time to do the Muzzy pistons/Webb cams. Will cost less than stock parts too...
    Thunder Tornado intake
    PCIII/Custom map
    Muzzy 2-1 meg exhaust
    55
    Quote Originally Posted by troop View Post
    I seen that but i'm not real hip on upping the compression. Does anybody else make pistons for this bike??
    55
    Bored out of round!!
    Got the bores checked this morning and they are out of round! The front front bore is out by almost .005 and the rear is just .002 so I ordered the oversize pistons and rings with all gaskets and seals come to just a tick over $500.00 not bad! This includes both front and rear KACR unit for the cams...
    Site Elder DreamStreak's Avatar
    Nov 2006
    Hiram, GA
    43
    998
    18 times
    Well at least do a little port work on those heads while you've got it out. It is against the law to repair without upgrading.
    2006 Mean Streak
    Muzzy Big Bore Kit
    Thunder Cams
    Heads Ported by Me
    Intake Ported by Thunder Manufacturing
    PCIII-Custom Map
    Forcewinder Air Intake
    Muzzy 2 into 1 Megaphone Exhaust
    Reed Valve Block Off Plates
    Mustang Seat, Fender Bib, & Tank Bib
    Jardine Forward Controls with mini floorboards
    Kuryakyn ISO Grips with Stilletto ends
    Up-And Comer orangeRcode's Avatar
    Jul 2009
    Mustang, OK
    52
    103
    Quote Originally Posted by DreamStreak View Post
    I like the way you think.
    2005 Meanie
    2005 ZX6R (sold)
    1975 Z1
    Up-And Comer slowhand's Avatar
    Oct 2006
    Tampa, Fl
    38
    My meanie is in the shop now for loud knocks. I did the same thing with the pipes to discover the noise. But, mine is from the bottom end. I was told it was a spun rod bearing. Hope yours (02 streaker) heals well!
    Site Elder razir66's Avatar
    May 2009
    Dane, WI
    580
    Man, you guys are making me paranoid. Anytime I hear some clacking, I'm going to assume the worst. My bike only has 2k on it, but it does clack, especially on startup, which I'm sure is normal from the oil not being sloshed around yet. I guess there are so many different types of engine noises, you must discern which ones are 'normal' and which ones aren't.
    2006 Black Mean Streak, Kawi 2-up seat, CWI Mini-Backrest/Rack,
    Pro-One grips, Thunder Intake w/Factory Cover, PCiii USB,
    Road Burner Road Pro's Chrome, Jardine California Boards,
    Memphis Shades Alley Cat shield, F&S Strut Covers,
    Easy Brackets, Saddlemen Drifter Teardrop Bags
    55
    Quote Originally Posted by slowhand View Post
    That sucks on the rod bearings! That will cost you more than me. I can at least do my own labor as I use to work for a kaw dealer years ago. Since thay have yours down tell them to check your bores and those KACR units!! Good luck...
    Nov 2006
    Hiram, GA
    43
    998
    18 times
    I took the front KACR off, just using the rear one.
    2006 Mean Streak
    Muzzy Big Bore Kit
    Thunder Cams
    Heads Ported by Me
    PCIII-Custom Map
    55
    I wondered what would happen with them both off? Mine are so sloppy I don't think they were doing anything anyway. But I ordered two new ones just the same, dealer said they have been updated to a newer style but he didnt know why. Guess i'll find out?... Kaw discontinued the .020 over pistons and changed to a .050 over size which could be the 1600 standard piston? What is the bore size on the 1600???
    Supreme Being Tom_E's Avatar
    May 2008
    SE Wisconsin
    65
    1,884
    .020 over pistons for a metric bike are usually .020 inches, 0.50 mm. In the parts book, the OS will be .25mm or .50mm, etc.
    Kawasaki offers STD and 0.50mm OS for the 1500 MS.
    1500 and 1600 pistons are the same diameter.
    Mid 80's Evo Harleys had weak starters, we'd rewire the kill switch so you you could spin the motor on the starter with the kill switch off and after it started turning over flip the kill switch on and it would fire up. It's a trick that's an alternative to compression releases.
    55
    NO pistons!!!
    Kawasaki don't have any pistons available in the US oversize for the streak! Looks like they will be comming from japan. Guess I won't be doing any more riding this year!!!
    May 2008
    SE Wisconsin
    65
    1,884
    Good excuse for a big bore kit and cams.
02 kawasaki vulcan 1500 engine noise
1500 vulcan engine noise
1997 vulcan kawasaki motor noise top end.
2005 vulcan 1600 valve noise?
95 kawasaki vulcan 1400 knocking fix
kawasaki 1500 engine noise
kawasaki fs730v valve noise
kawasaki vulcan 88 engine knock
kawasaki vulcan engine knock
vulcan 800 engine noise
