Changing brake pads
Changing brake pads
This is a discussion on Changing brake pads within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; Anyone have info on how to change front brake pads? I changed the back, but the front i would'nt know where to start. By the ...
Results 1 to 4 of 4
    Up-And Comer freightman's Avatar
    Apr 2007
    Jacksonville, Fla
    52
    89
    Changing brake pads
    Anyone have info on how to change front brake pads? I changed the back, but the front i would'nt know where to start. By the way i think i need to take my bike to a machine shop to extract that exhaust header bolt, i broke an easy out inside of the drill hole, and now it's harder to drill out than the bolt itself.
    Site Elder zootech's Avatar
    Jun 2005
    Columbus, OH
    40
    972
    Fronts are just as easy as the rears. Couple of allen bolts and some clips/pins and they're out. Don't even need to crack open the manual.
    ~Bikeless~
    Rising Star MeanMachine's Avatar
    Dec 2006
    Enterprise, AL
    43
    256
    I concur with Zootech, fronts are as easy as the rears.
    And B., Yeah, I'd go to a machine shop if you've broken the easy out. Without the right tools / experience, you may never get that thing out. Sometimes it's worth spending the scratch to have someone who knows what they're doing take care of it.
    2003 Mean Streak
    MBW LED Turn Signal Array - Radiantz LED Side Mount License Plate - Wicked Image Gothic Mirrors & Arms - Kuryakyn ISO Grips w/ Stiletto Tips & Throttle Boss - Clear Alternatives Taillight and Front Turn Signal Lenses - Jardine Forward Controls - Coasters - Dobeck TFI - Dual Cadmann w/ High Flow Filters - HK Stripper Straights - Rectifier Relocated - Stebel Horn - Show Chrome Switch Housings - Cobra Swing Arm Cover - Kawasaki Fire & Steel Passenger Peg Eliminators - Low and Mean Long Front Fender - Low and Mean Chin Radiator Shroud - Danny Gray Flame Seat - VTX Shocks - Ignition Relocated - Pro-1 Chrome Idle Adjustment Knob Cover - Custom Paint - Chrome Exhaust Bracket - Baron Custom Master Cylinder Covers - Cobra Drive Shaft Bolt Cover - Maruader Headlight
    http://s283.photobucket.com/albums/k...0-%20February/
    Apr 2007
    Jacksonville, Fla
    52
    89
    Thanks guys for the help, glad I found this site, everyone been very helpful.
2002 meanstreak front brake
brake pads meanstreak
front brake pad install 2006 kawasaki concours
how to change brake pads on 2002 mean streak
how to change brakes '03 kawasaki mean streak
how to change breaks on a 2003 kawasaki meanstreak
how to change front brakes on 2003 kawasaki
how to install front brake pads on a 2003 kawasaki mean streak
how to replace front brake pads mean streak
replaceing brake pads on 2003 kawasaki mean streak
