Run-Turn-Brake
Run-Turn-Brake
This is a discussion on Run-Turn-Brake within the Mean Streak Accessories forums, part of the Kawasaki Mean Streak category; I finally got around to trying something for run-turn-brake. It works pretty well, the camera was only about 2ft. from the bike so you don't ...
Results 1 to 2 of 2
Like Tree3Likes
  • 3 Post By lee
Thread: Run-Turn-Brake
    lee
    lee is offline
    Supreme Being lee's Avatar
    Dec 2011
    Lancaster, CA
    2,585
    1324 times
    Run-Turn-Brake
    I finally got around to trying something for run-turn-brake. It works pretty well, the camera was only about 2ft. from the bike so you don't get the effect of the main taiil light but can see the signals pretty well. Check out Rear Running Lights Mod « Bareass Choppers Motorcycle Tech Pages. I went almost exactly from their guide. There's a little difference in how the covers screw on, I had to make a cutout on each side. I might have another go at it since I have Lexan left over. That stuff is tough, not much need to worry about drilling close to an edge as it turns out.
    https://plus.google.com/113736821984...ts/AX6TW1urdf5
    bearclaw, madperson and CodeInVB like this.
    Supporting Member Dustin's Avatar
    Dec 2013
    Tuscaloosa alabama
    33
    513
    434 times
    Looks good
    The honesty and integrity of one can lead thousands
    Parts in bike
    I have every part that bad ace makes
