Jardine Forward question
This is a discussion on Jardine Forward question within the Mean Streak Accessories forums, part of the Kawasaki Mean Streak category; So,... I'm on my second set of Jardines,... and I can't get the brake adjusted out right. The back brakes are REALLY stiff,..... almost feels ...
So,... I'm on my second set of Jardines,... and I can't get the brake adjusted out right. The back brakes are REALLY stiff,..... almost feels like I'm standing on it to get it to apply,... then with just a bit more pressure,.. it locks up. Both sets have been the same way. I adjusted the pedal back up to where it's almost uncomfortable to use,... and it's still not any better.
I'm 6'2" with a 34" inseam and sz 14's. Adjusting any higher up just isn't an option. Anybody have any idea on this??
One other question. After I got this set on,.. and was adjusting the brake light switch,... I noticed that my front brakes aren't activating the brake light anymore. I can feel the switch clicking when I apply. Any ideas???
04 Marauder,.. the Mean Streak's better looking brother!!
"Wet Black" wheels with red stripes
"Wet Black" forks with Racetech Springs and VTX rear shocks
Memphis Fats 21" Gradient Black
Mustang 2 pc. Seat with Mapam Backrest and Luggage Rack
Jardine Forwards with Mini-Floorboards, Dually Passenger Pegs and ISO grips
Muzzy 2-2,.. debaffled
Chucksters intake with K&N filter and cover, Wild Things Processor
Red Engine LED's and LED turns
08-10-09 10:48 AM
Site Elder
If the bushings at the pivot point are too tight they could bind up. Adjust the pedal to where it feels comfortable and work the linkage from there. Obviously, there could be some linkage binding from disassembly/reassembly, so don't forget to double check the master cylinder mounting and connection to the forwards. The easiest way to tell if it is the jardines is to unhook the master cylinder and see how freely the linkage moves. If it is still binding, I can't think of anything other than the bushings that could cause it.
2006 Mean Streak
Muzzy Big Bore Kit
Thunder Cams
Heads Ported by Me
Intake Ported by Thunder Manufacturing
PCIII-Custom Map
Forcewinder Air Intake
Muzzy 2 into 1 Megaphone Exhaust
Reed Valve Block Off Plates
Mustang Seat, Fender Bib, & Tank Bib
Jardine Forward Controls with mini floorboards
Kuryakyn ISO Grips with Stilletto ends
