Hey all, what's the best and most affordable highway pegs we can get without having an engine guard? I saw in the pictures thread that some of you have pegs that connect to the frame. Where'd you get them?
Thanks!
This is a discussion on Highway pegs with no engine guard? within the Mean Streak Accessories forums, part of the Kawasaki Mean Streak category; Hey all, what's the best and most affordable highway pegs we can get without having an engine guard? I saw in the pictures thread that ...
Thanks!
You just need the kind that clamp to the frame. Pretty sure it's 1-1/4" so your possibilities are rather limitless. Check out www.phatperformanceparts.com, I've always had good luck with them.
I have the Kurakyn ISO's and like them, infinitely adjustable to where ever you want them.
http://www.cruisercustomizing.com/de...ir&model_id=46
02' Meanie
Candy Gold Spark
Hard-Krome American Classic Pipes
Stainless Brake & Clutch Lines
Chrome R/R Cover
Dynojet PCIII USB
Right Side Cadmann Air Filter
ISO Grips
Kuryakyn/ISO Highway Pegs
Cobra License Plate Frame (with LED bolt lights)
Avon Storm ST's 130/180
Kuryakyn Silver Bullet Riding Lights
02' Meanie
Candy Gold Spark
Chrome R/R Cover
Dynojet PCIII USB
ISO Grips
XX
How do you use your rear brake with those? Looks like it'd hit real quick.
XX
Jon, looks like you have installed what I have been thinking of...
How do they work in relation to the shifter & rear brake.
Thanks,
RGR
2002 Meanie
02' Meanie
Candy Gold Spark
Chrome R/R Cover
Dynojet PCIII USB
ISO Grips
02' Meanie
Candy Gold Spark
Chrome R/R Cover
Dynojet PCIII USB
ISO Grips
I can vouch for the Kuryakyn not interfering with the shift or brake as I have the same setup. The pegs use an offset adapter which allows you to rotate 360 to a comfortable position and thus, allowing you to set them away from the two controls. The only issue is making sure they are tighten down thoroughly.
