Kawasaki used to make neck cover for our bikes but I can't find it anymore. My wife's VN900 looks great with the neck cover. Anyone else has a solution? Thanks!
This is a discussion on ugly neck on our MS within the Mean Streak Accessories forums, part of the Kawasaki Mean Streak category; Kawasaki used to make neck cover for our bikes but I can't find it anymore. My wife's VN900 looks great with the neck cover. Anyone ...
David davis makes a set up for the meanstreak that looks good, but its expensive, it replaces the plastic piece on the gas tank and the radiator trim piece, it all flows together and comes sanded and primed. you can email him at daviddavis@wildblue.net and he will send you some pics and prices. He is the same guy that makes the hot box for our bikes.
2007 SE. Muzzy 2into1 exhaust, tornado intake, PC3, Custom sidemount w/ radiatnz led frame, clear alternatives integrated tailight, 1.25" bars, HEL black braided brake/clutch lines, iso grips with stilleto ends, corbin young guns/ dual tour seats, custom dynamics wrap around front turn signals. Lots of powder coated parts, Progressive front springs with 12.5 wt fork oil , and progressive 440 12.5" rear shocks.
Can someone post a pic up so we don't fill David Davis' mailbox?
Here you go.
2003 1500 Mean Streak
Honda Blue/Lamborghini Orange Custom Paint, Kuryakyn Pro Series Hypercharger, Chrome Horn/radiator cover, Bub Jug Huggers Exhaust, Power Commander, 12" 412 HD Progressive Shocks, Engine Ice, Kuryakyn Turn Signal Mirrors, Kuryakyn Inspection Plate, Kuryakyn Iso Grips, Demon Cycles 1.5 inch bars with 8" rise, Cobra II Headlight, Chrome Cable Covers, Reed Valve Block off Plates, Danny Gray High End Raven Flame Seat, Kewl Metal Fat Fork Kit, Cobra License Plate Kit, Chrome Levers, Dakota Digital Gauge, Rectifier relocation bracket below radiator, Hot box, Mapam Forward Controls, Avon Storm 200 rear/120 front, meanmachinist risers, Stainless Steel Lines, chrome switch housings
Soon to come:Cobra Floorboards for the longer rides, Kewl Metal Pro Street Kit(45 degree rake)
1982 Kawasaki KZ750E
1972 Jawa 350 (restoration project)
"Windshields are for Cars"
** Gone But Never Forgotten**
Thunder Tornado intake
PCIII/Custom map
Muzzy 2-1 meg exhaust
*Now a H-D bagger owner with a 103"/cams/head work build in progress*
Hi guys,my name is Dave Davis and as pictured I make a solution to the exposed neck area.Someone said it was a bit expensive.Compared to just a simple piece to cover the neck your right but,when you also solve the problem of the radiator hanging out front and compare this to Low and Means attempt to cover just the radiator my solution is a bargain and looks muchhhh
better.Please contact me if I can help in any way.I don't mind if you fillup my mail box.I should have my website up soon and will keep you posted.
Thanks much
Dave Davis
540-872-3977
Dave Davis
