Help
Help
This is a discussion on Help within the Graeme's Trip Around Oz - 2004 forums, part of the Daily Ride category; hola a todos disculpen tengo un problema con un accesorio de dynojet primero tengo una gsx1000 k8 Con los sgtes accesorios pcv Autotune quickshifter POD-300 ...
Results 1 to 5 of 5
Thread: Help
    Newbie power_rizla's Avatar
    May 2015
    47
    4
    Help
    hola a todos
    primero
    pcv
    Autotune
    quickshifter
    POD-300
    mi problema es con el último (pod300)
    Lo que pasa es que grabó una ruta en el pod 300
    lo quiero exportar a excell y el programa usa el formato csv
    y para acomodar los datos en forma de tabla
    se acomodan erróneamente
    luego en el winpep 8 las gráficas
    y sobretodo la vista de wb2_afr
    Salen con valor cero
    Por favor alguien sabe o tiene el mismo aparato
    Supreme Being Easy Rider's Avatar
    N. Central Florida
    3,123
    460 times
    Rough translation courtesy of Google:
    Hello everyone
    sorry I have a problem with an accessory dynojet
    first
    K8 have a gsx1000 sgtes accessories
    pcv
    Autotune
    quickshifter
    POD-300
    my problem is with the last (pod300)
    What happens is that a path recorded in the pod 300
    I want to export to excell and the program uses the csv format
    and to accommodate the data in table form
    They accommodate erroneously
    then in August winpep graphic
    and especially in view of wb2_afr
    They come out with zero
    Please someone knows or has the same apparatus
    Supporting Member THEMANRACING's Avatar
    Moore Oklahoma
    4,318
    751 times
    Call DynoJet and talk to tech support. They are EXTREMELY helpful. They have amazing customer service.
    May 2015
    47
    4
    Ok
    May 2015
    47
    4
    Problem solved
