Help me fine tune my carbs *video*
This is a discussion on Help me fine tune my carbs *video* within the General ZR-7 forums, part of the Kawasaki ZR-7 category; Ok guys, first off thank you guys for the help thus far! Bike is running phenomenally better than when I got it! To date here's ...
Results 1 to 15 of 19
    Up-And Comer 99GrandTouring's Avatar
    Mar 2003
    West Virginia
    36
    99
    To date here's where I'm at.
    Petcock rebuilt, all new fuel and vacuum hoses.
    Ivans jet kit, needle clip on 3rd slot, mixture screws 2.5 turns out, holes in airbox as specifief, new float needles and all float levels set at middle of carb right at bowl seam, carbs bench synced, no vacuum leaks.
    It runs great on highway, but now it's got an off idle stumble that was not there before, also idle baloons / hangs at times..
    Here's a video of me turning the idle down (couldn't do that before) re-setting it, and you can see the hang up right before 2k rpms, esp near 30seconds.
    What if anything can I do to tune out this last little bit? Mixture screws richer or leaner?
    https://youtu.be/BQJJA2kuC0g
    Mar 2003
    West Virginia
    36
    99
    Also in video throttle was cracked open about 1/8 - 1/4 and held, not rolled full open.
    And throttle position sensor is reading / adjusted to
    1.09v @ idle
    4.11v @ wot
    1,688
    567 times
    Videos audio wasn't very good but, the "off idle hesitation/stumble" could be a number of things. Could be something as small as a tiny air leak somewhere, or combined with the rpm hanging up slightly on the return could be the carbs need fine tuned synching with gauges. One carb slightly "off" from the rest can cause this. A shop with proper gauges can do it quick and easily for minimal cost. The K-trik sensor possibly but, I'd lean toward other cause(s) IMO. I've never "adjusted" mine but, even disconnected, it didn't make a real noticeable difference. The sensor values/specs are in the manual. Someone here like Obo, Shakey, LP, or others I'm sure has the info on that...Congrats on getting it running as well as you have to this point tho.
    Mar 2003
    West Virginia
    36
    99
    Well I messed around with the mixture screws for testing
    I was running @ 2.5 turns out so I tried 2 turns out no improvement, so I tried 3 turns out, ran much better / almost all hesitation gone. Only hesitates very slightly near 1k rpms when doing very slow parking lot manuevers
    Before when coming up our long hill if I was in 4th around 2k rpms ( bogging heavy load on engine) it would start bucking and jerking when rolling on the throttle.
    Now @ 3 turns it just smoothly and steadly pulls.
    I honestly think going higher than 3 would be better but I read somewhere that running @ 3 turns out is potential for mixture screws to loosen and fall out?
    Any suggestions? I really don't want to mess with changing idle jets..
    1,688
    567 times
    Try moving your needle clips and see if that enrichens it a bit more, and turn up your idle a bit. 1000 is at the bottom of rpms for idle.
    Site Elder lpscruggs's Avatar
    Cheney, Kansas
    664
    102 times
    Talking
    Well I'm no expert on carb tuning other than saying adjust only 1 thing at a time. I like Factory pro in that they sell really good jet kits but also sell spark advancers too and that counts for a lot IMHO. But my 01' ZR7S is running unmolested, engine wise. I learned the "hard way" from my KZ's & GPZ's & Zephyr 750's. I got tired of chasing the tune up on them after changing exhaust (full exhaust & slip on mufflers) air filters, air box mods separate clamp on air filters air injection system removal ect. IMHO the engine was just fine stock. I'm going to put my time and efforts in suspension compliance and good handling and riding comfort. The only thing I'm doing is replacing the air mixture/ bleed screws to the long ones that Factory Pro sells that are much easier to adjust on the fly for when I go to ride in the Rockies. As far as the off idle stumble I think that is a low part throttle lean condition so I'd raise the needles (lower the clip 1 notch) if that is worth the time for something that happens at super low speeds. Remember you can lower the needle and use thin shims under the clips to make "finer adjustments". Also I like buying jet kits from places that will give you some help on the tuning side, as the Factory Pro folks do. Also you can use a vacuum gauge to get "close" on the air bleed screw setting. This is all my opinions and nothing else. Because as I said I'm doing my best to leave this motorcycle engine unmolested if possible. After all that's why I went to Japanese motorcycles, because of the reliability and the more smiles to the mile compared to the U.S. & European brands. Also "bench syncing is ok but you need to do it with the engine running with a sync gauge. Buy one and you will become very popular to the point that if you'll help out a friend you will quickly have so many 6 packs packed away that you won't be buying any beer again. Don't ask me how I know this. I'll deny it, lol. Ib sure wish we lived closer. but with the internet I guess we do. Honestly I really don't see much of a stumble or hanging of RPM's on your video. That will decrease when completely warmed up. Get yourself an inexpensive infrared laser thermometer and check for when the temps "stabilize". I sounded good to me.
    99' ZR7 Blue
    01' ZR7S Red
    05' ZRX1200R Green
    Mar 2003
    West Virginia
    36
    99
    Thanks LP, I'll try moving to clip to see.
    I have an IR thermometer, where / when should I check temps?
    Mar 2003
    West Virginia
    36
    99
    I pulled the plugs just to check them...
    Nottingham(UK)
    1,247
    268 times
    carbs bench synced only gets you in the ball park really.
    use some of these, to finish off
    Kawasaki ZR7
    1,688
    567 times
    Maybe you didn't read but, post #3 and #5 recommended you synch with gauges and move the needle clips?
    Mar 2003
    West Virginia
    36
    99
    I'm working on the synch tool found some videos online, going to make one..
    1,688
    567 times
    That could be a fun project. I have a really old set that still uses mercury. I've seen a basic set at Walmart for about $60 also. It will make a big difference on how well your bike performs when done correctly. Good luck.
    Cheney, Kansas
    664
    102 times
    The spark plugs basically look ok I'm sure they have been there for a while, they aren't wet or oily meaning that the engine is not grossly out of whack. To read plugs properly you need to warm up the engine, shut it off install new plugs run the engine at load shut it down and pull the plugs and have a good look. That said if you want to look at the plugs to diagnose any carb setting issue you have to start with "fresh plugs" not some that have been in for several thousand miles. So install new OEM brand and heat range spark plugs sync the carbs get a tank full of fresh fuel and give it a good ride spending some time zipping along every where from idle to high speed then do a plug check. Honestly I think you probably have it running pretty good. If it is running as good as it looks well, it's doing good. Oh remember to use some anti seize compound on the plug threads to protect and lubricate the treads in the cylinder head and spark plugs.
    99' ZR7 Blue
    01' ZR7S Red
    05' ZRX1200R Green
    Mar 2003
    West Virginia
    36
    99
    Well here's what I've been working on. .. my homemade manometer / carb balancer...
    First try was using plastic bottles. . Was doing great till a bottle collapsed, new v2 has glass bottles, had to pull carbs and re bench sync, will try tomorrow to balance them
    SCB
    SCB is offline
    Newbie SCB's Avatar
    Dec 2016
    Nazareth, PA
    60
    24
    I'd never seen this type of DIY set-up before, only the ones with tall U-shaped tubes. This can work but you'll have to be sure there are no vacuum leaks anywhere in the system.
    One interesting difference between this set-up and the U-shaped tube is with Utubes you adjust the carbs until the fluid level in all tubes is the same. With the Jar set-up you don't care about the level in each jar but watch the flow of fluid from one jar to another. When there is no flow the carbs are balanced, regardless of the levels.
