Front sprocket cover required?
This is a discussion on Front sprocket cover required? within the General ZR-7 forums, part of the Kawasaki ZR-7 category; Running factory sprockets won't work with my GSXR swingarm...chain rubs the arm. I'm going to have to go with larger front and rear sprockets, but ...
Results 1 to 15 of 21
    Up-And Comer makenzie71's Avatar
    Dec 2016
    136
    Running factory sprockets won't work with my GSXR swingarm...chain rubs the arm. I'm going to have to go with larger front and rear sprockets, but I can't get the correct height on the front with the sprocket cover. Any reason I can't just leave it off? Alternatively I'll chop the thing up.
    Only thing I saw that concerned me was a small "pin" toward the front lower corner of the sprocket cover area. What's that pin/shaft for? Having a hard time finding it in the service manual.
    8,498
    1497 times
    I wonder if the pin is a locating pin? Sometimes used, on covers, to make sure it fits in place perfectly?
    We did this on our dirt bikes, the running without a cover. It was better to prevent mud build up. There never was a problem as long as you were wearing boots.
    Well, one afternoon, I decide to go for a quick spin. No boots needed for a short ride, right?
    The pants I was wearing were old levis, and thank god they were old. The levis were grabbed by the sprocket. It ripped the entire left leg off, crotch section and all. I looked like a want-to-be flasher.
    It was very funny, but had those pants been new and strong, it could have gone badly.
    Dec 2016
    136
    It doesn't look like a locating pin...or not the same kind that I'm use to seeing with other bikes (of all my bikes this is my second Kawasaki). It's possible.
    However, I think the problem I'm going to have, though, is with the shifter. The shaft sticks out quite a bit and flexes when I try to shift. It might clear up some once my rearsets are solidly mounted, but I think I'm going to need a carrier for that shaft at the very least. I'm going to take a closer look at the cover later and see if it can't possibly be dished out enough to handle a much larger front sprocket.
    A lot of my bikes had no front cover and I never had a problem...I always wear boots and have my cuffs and laces tucked for similar reasons so apparel has never been a concern. But I've had a couple where the front cover held some other vital component in place (like a clutch push rod on a 1983 XS400 which shoots out on a fountain of oil if you start the engine with the cover off). I have idled the bike a bit with the cover off, though, and nothing bad has happened that I've noticed...but I'm reluctant to ride it without knowing for certain.
    8,498
    1497 times
    That shift shaft.....I swear Ive seen people build brackets to reinforce that....I had to on an old r1 that needed it ..something like this:
    Orient Express : Honda Grom Billet Shift Shaft Support | Dragbike.com
    Your bikes have that industrial look. Maybe a cover like this?
    WR250R WR250X Zeta Front Sprocket Cover
    8,498
    1497 times
    Heres what I was thinking....You could build this: Sorry, it wont let me save the picture...
    Racing Cafè: Suzuki GSX 1100S Katana RCM-126 by AC Sanctuary Tokyo West
    If you scroll down, there is a close up of the front sprocket and cover.
    I also saw one of their bikes where they used the stock cover, but made a cut-out to clear the sprocket.
    Dec 2016
    136
    I actually rather want to build that whole bike...maybe when I'm older, have fewer obligations, and a little more spending money haha...I've wanted to build a GS1100 Kat around a built B12 motor for the longest time.
    That cover, though, is pretty much what I'm thinking. Probably not that elegant, but same premise. I really need a mill...
    4,454
    900 times
    The pins (with the rubber covers) are just there as spacers to hold the cover out from the sprocket and chain. It stabilizes the cover as well as the shifter rod runs thru it and pivots in it when you shift.
    8,498
    1497 times
    Great point, obo......If the cover was not located 100%, or strong, it would not support the shaft, would it?
    Dec 2016
    136
    This is the pin I'm talking about.
    4,454
    900 times
    The Shlerblonger pin? It's for alignment for the fastening bolts in conjunction with the shifter shaft.
    4,454
    900 times
    Yes, if it wasn't there the shifter shaft would want to snap off where it leaves the engine case vs rotate like it's suppose to.
    Dec 2016
    136
    I'm not saying it's not a locating pin, but there were locating pins on the sprocket cover (the kind that recess into the bolt holes) and I've never seen one like that before. Good to know it's not worth worrying about! When I make a new cover I don't think I'll put a lot of effort into covering it up.
    8,498
    1497 times
    Obo makes sense.....I dont think we;ve come up with the word for the pin.
    My dirt bike has no pins. When you put the cover on, its holes are oversize. Or is that oversized?
    Anyway, you could put the cover on and have it several millimeters out of place. If that were true here, its totally far enough to bind the shift shaft. This pin prevents that......
    Dec 2016
    136
    The locating pins are pretty snug in their corresponding holes. I've got two complete engine setups here and both have that little pin on the engine, and the corresponding hole on the sprocket cover is visibly larger.
    Mystery pin! I'm writing a letter to Kawasaki.
    I'll add...the reason I don't think it's a locating pin is not just because the corresponding hole is larger, but the pin itself looks worn. Like it's a moving part. There's "gap" around it at the base unlike what you'd see with a fixed pin. It "looks" like it's suppose to move...like it either plunges or rotates...but I could not get it to move at all (honestly did not try very hard). It's also soft...it's not aluminum but it's hardened steel.
    8,498
    1497 times
    Did you post a pic of the pin? Id like to see it.
    Des Kawasakis parts diagram call it anything but a pin? Maybe that could offer a clue?
