Are the ZR7 and ZR7S frames the same?
This is a discussion on Are the ZR7 and ZR7S frames the same? within the General ZR-7 forums, part of the Kawasaki ZR-7 category; Title says it. Having a hard time getting my existing frame titled...looking at a frame to swap everything over to but it's not an S....
    Up-And Comer makenzie71's Avatar
    Dec 2016
    141
    Dec 2016
    141
    No. They are not.
    Specifically the tab on the steering column to hold the forward stay is not present on the standard. Decking a standard out to look like an S will require welding.
    1,688
    567 times
    Good catch. I assume that's where the "fairing bracket" is anchored to it. Most go from "S" to naked but good info.
