Stalls or stumbles, when throttle is first opened, any suggestions.
This is a discussion on Stalls or stumbles, when throttle is first opened, any suggestions. within the General ZR-7 forums, part of the Kawasaki ZR-7 category; Can a carb guy tell me what I'm missing. I cleaned my carbs twice. The bike stalls when you first crack the throttle, between 1,000 ...
Results 1 to 9 of 9
    Newbie Kitt's Avatar
    Jun 2012
    Can a carb guy tell me what I'm missing. I cleaned my carbs twice. The bike stalls when you first crack the throttle, between 1,000 and 1500 rpm. Above that it runs fine. I've cleaned the pilot jet, pilot screw, every orifice I could find, but still have this problem. I've even popped the gas cap to see if it was a vacuum problem.
    Supreme Being Smash's Avatar
    Denver, CO
    6,805
    700 times
    Have you replaced the pilot jet? Those dang little things are hard to get really clean.
    Johnny Blue Lightnin'
    JonF's Avatar
    Mar 2002
    Felton, DE
    53
    12,117
    116 times
    Your idle should be 1100-1150 rpm I think. Where are your idle mixture screws set?
    2,199
    180 times
    carbs sync'd?...floats set right? whats your idle?..did you SOAK all removeable parts in carb clean?..did you blow all passages(including removeable parts) out with 120psi of air?..any passage you could look thru did you?
    Jun 2012
    Quote Originally Posted by JonF View Post
    Mine are set where they have been at 2 & 1/2 turns out. Its run fine at that, in the past. The pilot jets are clean. Does anyone know what the air bleed pipes are. There mentioned in the manual as possible culprits.
    JonF's Avatar
    Mar 2002
    Felton, DE
    53
    12,117
    116 times
    I think the air blleds are drilled within the carb bodies and capped with lead plugs at the factory. They are usually quite small. They either allow metered air into parts of the carb or allow air into passages used by fuel to allow the fuel to move freely without creating suction and starvation or to help the fuel atomize.
    Silver Member buster's Avatar
    May 2004
    pinellas park Fl.
    61
    1,727
    15 times
    mine did that when i removed the airbox snorkel. i shimmed the needles with a radio shack washer and still did not fix it completely. my carb guru took the springs and stretched them out just a tad and that fixed it.
    It is better to remain silent and be thought of as a fool,then to open your mouth and remove all doubt. Abraham Lincoln.
    Jun 2012
    Quote Originally Posted by buster View Post
    Thanks, I have also shimmed my needles, but what springs were you refering to ?
    Up-And Comer efjaxx's Avatar
    May 2003
    ATL, GA
    58
    94
    Quote Originally Posted by Kitt View Post
    I recently started having this problem after the EGR-ectomy. Stumbles a little after 2-3 min warmup when pulling out, then runs fine afetr first mile or two. Anyone have any suggestions?
    ZR7OA #533
    HYPER-LITES, CLEAR LED TURN SIGNALS, DIY SEAT LOWERING MOD, CASE GUARDS, UNGO ALARM, GOODRIDGE SS LINES, MIRROR EXTENDERS/MIRRORS, ZRX HANDLE BAR & RISERS, TWO TONE SMOKE/ FLAT BLACK PAINT, K&N FILTER, EGR-ECTOMY, & COLT .380
cb dies when throttle is opened
klr 650 dies throttle
klr650 dien on throttle
klr650 stalling in first
motorcycle stalls when open throttle
motorcycle stumbles when given throttle
my klr 650 dies when throttle is first cracked open
triumph 650 stalls when giving gas
what does synchronizing the throttle do for my king quad
zr-7 stalling
