Ignition switch
This is a discussion on Ignition switch within the General ZR-7 forums, part of the Kawasaki ZR-7 category; looking at the ZR-7 ignition switch wiring diagram, the grey ignition wire from the cdi to the switch in the on position is connected to ...
Results 1 to 5 of 5
Thread: Ignition switch
    Newbie siberhusky0's Avatar
    Feb 2012
    Ignition switch
    looking at the ZR-7 ignition switch wiring diagram, the grey ignition wire from the cdi to the switch in the on position is connected to what? The diagram just has a - mark. Example: Brown (ignition) is connected to white (battery) in on position. White/black (battery) is connected to white/green (tail 3) in on position. Gray (ignition) is connected to - (ignition) What is - ? Ground? Any help appreciated.
    1,009
    trying to hotwire one or need a switch?....ive got a spare switch and tank cap with key
    if your considering tapping off it for power do yourself a favor and tap off the battery with a relay useing a relay and a keyed on wire out of the fuse box under the seat
    Feb 2012
    Thanks for the response... I got the engine for a mini sand rail is the reason for no switch. Bought a wiring harness & CDI off of ebay. Engine turns over no problem (have handle bar switches connected temporarily) jumped across wiring for kick stand & clutch lever switch. The grey ignition wire according to the switch diagram is what I don't follow,...don"t know if it is suppose to connected to a hot wire, ground or what. Don't know what the - represents in the diagram. Bought the engine from a guy that wrecked the bike & he cut up the harness before I could get to it. The CDI I bought may be bad or the crank sensor, but need to be sure I have the wiring straight. Not getting a spark with the grey ignition wire momentarily connected to 12v & ground also. If you have a spare switch I would buy it even if only to ohm the terminals. That would clear up any question on wire connections.
    1,009
    hell ive also got the wireing section from a busted switch..i can test up for ya...just got back from victoria bc lastnight SOAKED gimmy a day or 2 and ill see what i can figure out
    Site Elder graeme.medley's Avatar
    Nov 2004
    Larbert, Central Scotland
    56
    985
    Don't worry about it.
    The grey wire is the live feed to the indicators.
    You can use it as a switched live if you need one.
    ZR7OA member #759
    1999 ZR-7 New Candy Wine
    Ignition advancer, Hugger, Braided steel brake lines, Progressive fork springs, FUEL end can, Fenda-extenda, Scotoiler Mk7 with HCR, K&N Filter, LED Rear Lights, Fuel gauge mod, GIVI rack plate and boxes:
    When fitted - Powerbronze Viper fairing, Stebel Nautilis horn, Relay mod to lights, Battery condition monitor.
    Waiting in the wings:
    ZX6F rear shock, Ivan's Jet Kit, Powerbronze Lazer Bikini Fairing.
01 zr 750 wiring diagram
change ignition kawasaki brown wire
how to remove a kawasaki zr7 ignition switch
kawasaki 7 wire ignition switch
kawasaki zr7 cdi problems
location of ignition fuse on zr7 kawasaki
wiring diagram for a cdi ignition for kawasaki 750
