I figured Id try to get a conglomeration of all the things you can do to your ZR with a stop to walmart, Home Depot, or equivalent. I've seen alot of stuff on here that would definately count as DIY, so hopefully this thread will see some use. Feel free to post up or PM if you got a good one, and I'll add a link into the initial post so that poeple dont have to search everywhere. I am also up to try more DIY mods, so all you gotta do is ask.
I guess I'll start it off. There are a bunch of these "mods" that are already posted.
Obviously, anything on the ZR-7 site is a bible to ZR owners:
http://www.zr-7.com/maintenance.htm
This thread is my own stuff that I have done. Includes DIY stuff like:
Straight Pipe - Stock Exhaust Mod,
Seat Reshape,
Fender Eliminator,
Home Made Phone Mount, and
Painted Side Panels.
Stuff I've Done to my ZR-7S (Very Pic Heavy)
Fuel Gauge Calibration
Fuel Gauge Calibration (Part 1/4)
Stainless Steel Brake Lines
Installed Galfer SS lines
Switchable Stock Underseat Power Supply
Switchable GPS power supply w/Pics
Mesh Side panel Inserts
Nice and easy
Home Made Tail Rack
http://www.riderforums.com/showthread.php?p=530510
Home made Backrest
Homemade backrest
Home Made PVC Engine guards
CHEAP ENGINE GUARD
Integrator Tail Light
the best tail light integrator write-up
GSX-R Mirror Install
GSX-R mirrors
Extra Brake Light - LED strip
http://www.riderforums.com/showthread.php?p=532045
Cheap Camera Mount - I used this and attached it my phone to it
Cheap DIY Camera Mount
Phone Mount
Pimp your ride? GPS + BT Telephone mounted to ZR-7S
Polishing Rims
Polishing Rims
And
Polishing Rims III
LED Turn Signal and Tail Light
Angel eyes lights, led brakes, led signals
LED Turn Signals, Detail Striping, and More
It is done!! with pix!
EL Gauge Lighting
01 - 04 gauge cluster
12V Accessory Power Socket
wiring multi-volt accessory plugs
Or
Accessory power outlet
Switchable Power Supply
http://www.riderforums.com/showthread.php?p=532436
LED Accent Lighting
Accent LED lights
Givi Rack Mounting Brackets for Lights
Electric Vest
Getting Ready for Spring (DIY Electric Vest)
Beaded Seat Cover
http://www.riderforums.com/showthread.php?p=532259
If for some reason you do not want your thread on here, I will happily take it down. I figured this would be good publicity for mods that are beneficial and cheap.
2Likes
LinkBack URL
About LinkBacks
Darren.
