Engine oil for Z1000 (Noise)
This is a discussion on Engine oil for Z1000 (Noise) within the General Z1000/Z750 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; So I had the first service done (by the Kawasaki agents) on the Z about two weeks ago. I have not been riding much since ...
Results 1 to 15 of 16
    Newbie speedyZ's Avatar
    Jun 2008
    16
    Unhappy Engine oil for Z1000 (Noise)
    So I had the first service done (by the Kawasaki agents) on the Z about two weeks ago. I have not been riding much since then so only really started picking this up lately.
    The motor seems noisier than before? Almost like an engine with noisy lifters. Anyone else notice this? The guys tell me the run in oil is slightly thicker than the oil the use for servicing.
    I think I should invest in some proper oil and rather just change the filter and oil again myself. Any recommendations?? Or should I just leave it as is and live with it?
    Rising Star CBR_Brutha's Avatar
    Farmington Hills, MI
    496
    Well an oil change it a cheap way to get some peace of mind, so you lose very little by doing your own change. Be aware, however, that these engines do loosen up as they break in. Hearing a bit of valve noise isn't necessarily a bad thing. In fact, on my race bike I set the valves a bit loose on purpose, which results in a noisy valvetrain.
    If you think it's unnaturally loud after the oil change, I'd have it looked at. If it stays pretty much where it's at now, then I wouldn't worry too much...
    ~Nick
    Sportbike Tracktime Midwest Instructor
    2003 Kawasaki z1000: Hooligan machine
    2003 Yamaha YZF-r6: Track bike
    Jun 2008
    16
    Thanks CBR Brutha, any recommendations on what oil I should try??
    Site Elder 03kraz1000's Avatar
    Oct 2007
    North Carolina
    969
    I live by repsol . . . it has not given me any reason not to be happy with its performance
    496
    Quote Originally Posted by speedyZ View Post
    Ask 100 people this question and you'll get 100 different answers. Best way to start a virtual riot on this forum is to start a thread inquiring as to what oil is superior.
    I use Amsoil 10w40, which I believe to be best b/c I've used it and had no issues. Others will say the same about the oil they use, and it'll be just as valid. Best bet is to not waste your time trying to poll people here for an oil recommendation. Read some tests (Google "motor oil bible", download it, & read it), then make a decision based on what makes you feel warm & fuzzy...
    ~Nick
    Oct 2007
    North Carolina
    969
    +1
    Jun 2008
    16
    Yeah I guess you right hey, how long is a piece of string.
    Will research some oils and get it done ASAP, I think just the piece of mind will make me feel better! Besides I was not happy watching the guy doing the service! Only thing he did right was adjusting the chain.
    Up-And Comer 03Z1000's Avatar
    May 2008
    Baton Rouge, LA
    30
    133
    Currenty I run Motul 300V. Shifts a little better than factory kawi oil, and clutch seems a bit smoother. Next oil change I will switch to Repsol, a buddy of mine owns a shop and also races a CBR1000. He has always run Repsol and has never had an oil related failure.
    To me, any good name brand oil designed for sport bikes will be fine, to each his own.
    2003 Z1000 Orange.....Stock pipes cut 5" - PCIII - Ignition Advanced - Air box mod - K & N -
    The fastest way from Point A to Point B is 10,000RPM's!
    Rising Star dennis14685's Avatar
    May 2008
    434
    Thicker oil should reduce noise
    Its a hot climate where i am so i use thick oil........engine and gear box should be smooth with new oil coz it did not break down the oil so qiuter then the factory oil......
    now im thinking it could be 2 things............................i think you first oil change was around 1600 km, unless you changed at 800 kiliometers. So if 1600 kilometers the exhaust manifold headers nuts maybe a bit loose, those should be tighterned to 13lbs per foot pounds (Those come loose). and follow the sequence.
    A lttle bit of cam chain noise is normal as the engine breaks in......but im not really sure what type of noise from the engine your hearing. Also if its a vibe noise, the lamp set and windshield get loose and vib, put your finger on thme to cut out that noise......those come loose to just tightern them up
    May 2008
    434
    I bet you checked the oil level? to much or to less oil will give that effect of the lifters......
    Quote Originally Posted by dennis14685 View Post
    Jun 2008
    16
    The service was done at 998Km, I have replaced the complete exhaust system and have already checked the header bolts. Phoned the guy up again yesterday and he said its pretty normal seeing as the Z doesn’t have a much covering the engine, as is the case with the ZX-10 for instance.
    Still trying to make my mind up with the damn oil. We are in winter now with day temps going up to around 15-17 deg C.
    Jun 2008
    16
    Yip oil level is spot on!
    Site Elder kawtoy_77's Avatar
    Jun 2007
    Elliott, IL
    929
    I use KawaChem 20-50 year round, and change it every 2k miles. No complaints here.
    WWW.RIDINGILLINI.COM (Local Forum)
    _________________
    1978 HONDA CB750K (SOLD)
    1977 KAWASAKI KZ1000(Old Skool drag bike)
    2003 KAWASAKI Z1000(totalled @7064mi. 10-13-07)R.I.P.
    2003 KAWASAKI Z1000(bought on 10-20-07)
    1980 Kawasaki KZ440 (CAFE Racer project)
    Super Moderators groovyone's Avatar
    Aug 2003
    Dickinson, TX
    6,446
    My dealer sold me 20-50 and I hated it, even in TX. I am running 10-40 now.
    Your road determines your destination
    - Unknown
    If you don't know where you are going, any road will get you there.
    - Lewis Carroll
    Supreme Being BB-z1000's Avatar
    Jan 2008
    Australia
    1,034
    i think whats important, rather than brand, or even synthetic vs semi synth is that you stick exclusively to the recommended viscosity!
    after all the most important aspect of oil is is viscosity level which attributes to how well it works in any given application.
    ::: Black 2007 Z1000 :::
    Rear hugger
    Eliminator + Cat eyes
    Race Levers
    Sliders
    Rad guard
    Yoshimura race
    Pirelli Corsas
    MX bars + grips
03 z1000 oil
06 z1000 motor noise
2003 kawasaki z1000 oil type
kawasaki z1000 motor oil
kawasaki z1000sx viscosity
oil capacity 2003 kawasaki z1000
oil for kawasaki z1000
oil grade for kawasaki z1000
oil specs 2003 z1000
what oil to use in a 2006 z1000
z1000 engine noise
z1000 oil
z1000 oil viscosity
z1000/engine oil capacity
z1000sx engine oil
