This is a discussion on That powerband hurts wheelies within the General Z1000/Z750 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; I find the power band on the Z1000 to be so strong and sharp around 7500rpm that it seems to screw up any wheelie attempt. ...
I find the power band on the Z1000 to be so strong and sharp around 7500rpm that it seems to screw up any wheelie attempt. The second the tach passes seven it wants to shoot up past the BP.
This bike feels like it has a turbo or something. I like high end power, but it seems to come on awfully strong and sharp.
you'll learn to work with it. when i'm riding slow i will keep it below 7500 anyway and when i'm riding them fast i use >7500 to ride em anyway, you're wrist will learn about it an compinsate
03 Z1000 with stock gearing and YOSH pipes.
Isn't that around the rpm that other members have discovered the secondary butterfly finally starts to open?
Admin @
Racing is an addiction only cured by poverty.
2005 Z750 R
Z750S with the following changes: 2006 ZX6R Limited Edition Forks 2006 ZX6R Front Rim 2007 Z1000 Triples Powerbronze Carbon Fiber Fender 2007 ZX14 Front Brake Rotors (310mm) 2006 YZF-R6 Monoblock Brake Calipers HEL Braided Lines, Black 2006 ZX6R Swing Arm 2006 ZX6R Shock Skidmarx Carbon Fiber Hugger 2006 ZX6R Rear Rim 2002 ZX9R Master Cylinder 2003 ZX9r Clutch Perch CRG Shorty Levers, Black Rizoma MC Aluminum Anodized Reservoirs front and rear Probolt Blue Gas Tank Filler Aluminum Bolt kit Probolt Blue Engine Case Aluminum Bolt kit Rear swingarm/suspension lift dog bones Arrow NiChrom conical slip-on Scottoiler Mk7 Powder Coated Case Covers
