Switching to the 180/55 rear from a 190
This is a discussion on Switching to the 180/55 rear from a 190 within the General Z1000/Z750 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Anyone do it? Is this a common switch? Good or bad? I usually switch to 180s in the rear because it improves turn-in, handling, blah, ...
Results 1 to 15 of 25
    Rising Star Jglisso's Avatar
    Nov 2006
    Fernandina Beach, FL
    30
    179
    I usually switch to 180s in the rear because it improves turn-in, handling, blah, blah, etc.
    How does it affect the Z?
    Rising Star sv1000rider's Avatar
    Jul 2005
    St. Louis, MO
    45
    371
    I put on a 180 rear tire on my first Z1000 and it felt a lot more nimble and easier to turn. Searching with "180 190" in the search field will pull up a lot of good threads on the topic. Good luck bro!
    Pulaski County MO sheriff - "If you go over 100 in this county, you go to jail."
    ____________________________________________
    '05 Black SV1000S
    '07 Green Triumph Speed Triple
    Supreme Being kawamania's Avatar
    Jul 2005
    salisbury md
    45
    1,479
    for the average rider and street riding I see no benifit from it as far as performance,now on the track may be a different story.
    Supreme Being Nudist's Avatar
    Nov 2006
    1,014
    As a rule of thumb, you can effectively manipulate the suspension heights (front and rear) to give you the same turn in effects.
    Ride Naked.
    COS-M1K
    1. of or pertaining to the cosmos: cosmic laws.
    2. characteristic of the cosmos or its phenomena: cosmic events.
    3. immeasurably extended in time and space; vast.
    4. forming a part of the material universe, esp. outside of the earth.
    Rising Star one2many's Avatar
    Sep 2005
    Laurel, Ms
    204
    Quote Originally Posted by kawamania
    Well said that man.
    I'm putting a 190 back on when I wear this on off. Plus, the 190 looks so much cooler
    Supreme Being weirdooh's Avatar
    Oct 2003
    Indiana
    39
    1,578
    I like the 180s. I'll put another one on
    Supreme Being 2nsane's Avatar
    Feb 2005
    Alaska
    36
    1,548
    OH yea, I like the look of a 200 on the back of a Z I dont have one because they dont make a 200 pilot power. But if they did
    Your local Coastie
    Up-And Comer CaptNemo's Avatar
    May 2006
    48
    136
    A 180 Pilot Power replaced the OEM 190 battleaxe on my '03. I wouldn't dare do this to the OE skin.
    Supreme Being Kawa-Jockey's Avatar
    Sep 2006
    DC Metro Area
    1,148
    Will 200's fit back there? Dang!
    Phillip
    Jul 2005
    salisbury md
    45
    1,479
    yes the 200 will fit no problem
    El Controlador KXonZ's Avatar
    May 2006
    Monterey Bay
    34
    1,074
    so what does the 2 hundy ride like?. anybody evr put one on? like the diff between a 180 and 190?( ie..really only slightly noticeable)
    The act of riding is a form of meditation, because the concentration that's required to safely ride a motorcycle tends to focus the mind in a way that eliminates other mental distractions that might interfere with the mission. This creates a single-mindedness that, in effect, displaces the continuous stream of thoughts that normally flow through our consciousness.
    Jul 2005
    salisbury md
    45
    1,479
    not a lot of difference from the 190 but I am not riding on the track neither
    Sep 2006
    DC Metro Area
    1,148
    Quote Originally Posted by KXonZ
    Yeah...I wanna see too.
    Phillip
    Supreme Being racerraul's Avatar
    Mar 2006
    Spring Hill, FL \ Cleveland, TN
    1,329
    Quote Originally Posted by Nudist
    Yup!
    I've said this several times... It is my opinion that most of the raving going on the switch to a 180 is all based on going from a worn flat centered 190 to a brand new 180. The diff between a new & worn tires are night & day.
    Now are there any differences in turn in from going to a new 180 from a new 190... on a 6 INCH rim? My educated guess would be "NOT night & day, under a controlled test".
    There will likely be a greater diff between a 180 in a 5.5 rim & a 190 on a 6.0 rim. But that 6.0 rim has got to change the profile towards the edge of the tire a bit to minimize any (if any) diff in turn in.
    Now the 180 is cheaper. That is always nice...
    Just saying that doing a comparison of a worn 190 to a new 180 is worth mentioning because even a worn 180 vs a new 180 will yield a night & day diff in feel...
    I have lowered the front end of my bike by 11mm & have the rear set up pretty stiff & the bike is very flickable with the 190...
    Site Elder rponiarski's Avatar
    Westbury, NY
    59
    973
    After my OEM Bridgestone's wore out, I tried going with a 180 Diablo on the back. In less than 500 miles I switched back to a 190. Bike felt skittish, wouldn't hold a true line and felt much less stable to me. Was able to sell the tire on e-bay, so I didn't take a bath on it. Stick with the 190's, IMHO...
    Richard M. Poniarski
    '09 Kawasaki Versys
    Candy Plasma Blue
    AMA #674623
    LIME # 7
