Yoshimura Exhaust 2016 Ninja
This is a discussion on Yoshimura Exhaust 2016 Ninja within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; Hi all, I'm thinking of replacing the factory exhaust with a Yoshimura RS4 exhaust. Installation seems to be quitte easy but I'm worried about some ...
Results 1 to 4 of 4
  • 1 Post By Sarge1992
Thread: Yoshimura Exhaust 2016 Ninja
    Newbie Rbarbosq's Avatar
    Oct 2016
    Hi all,
    I'm thinking of replacing the factory exhaust with a Yoshimura RS4 exhaust. Installation seems to be quitte easy but I'm worried about some modifications that I have to do with a power commander to change the factory settings. Can anyone explain me what this is all about ? Do I really need to use the Power Commander in order to install the exhaust ?
    Thx
    Up-And Comer Sarge1992's Avatar
    Feb 2016
    Tampa, FL
    24
    78
    15 times
    I have the Yoshi RS4 on my 14 650r, only mod I did was the PAIR block off. You don't need the power commander, but I hear it helps more with the exhaust popping on deceleration.
    Oct 2016
    Thx Sarge, since i'm a newbie, can you please explain what does PAIR block off means ?
    Feb 2016
    Tampa, FL
    24
    78
    15 times
    It's where you remove the hose to the PAIR valve and use 5/8" rubber caps to seal it up. The PAIR valve is just a secondary air injection system installed by the government for emissions. Considering you want to put on a Yoshi exhaust which will remove the catalytic converter on your bike from factory, you're already tossing emissions out the window. The PAIR valve mod will reduce the amount of popping in the exhaust under heavy deceleration caused by unburnt fuel vapors. Here's a link to a good writeup I found with pictures on how to. It says it's for a 2012, but it will be the same for your 2016.
    https://drive.google.com/file/d/0B9F...hNOWN6UW8/view
    feistyfoo likes this.
