DIY tank dent removal
This is a discussion on DIY tank dent removal within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; I have a dent in my tank and am looking at ways to get it mostly out without spending a lot of money. The dent ...
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By steveinsandiego
Thread: DIY tank dent removal
    Up-And Comer Tailgun's Avatar
    Jan 2010
    41
    I have a dent in my tank and am looking at ways to get it mostly out without spending a lot of money. The dent is about baseball sized and 3/4 inch deep. There are no creases, so it should be the best canidate for removal without welding. I tried the heating and cooling method without any success. I'm just looking to get it good enough that I can skim sime filler over it and repaint.
    Does anyone have any recomendations?
    Up-And Comer CytokineStorm's Avatar
    Jun 2012
    West&South Chicago burbs
    110
    Try the suction cup tool? Ding King is popular one. I know they make a smaller one that would be better since there is less area on the tank.
    I seen a video where he heats the heats with a sol panel reflector, just to soften the paint mainly I'm sure, then sticks a metal rod in with a rubber end wrapped in cloth to keep from scratching anything and pushed it out.
    I have one too, I just don't know if it's worth fixing since I may be painting in the off season(winter)
    Other than that I doubt there's a magic fix. The weld/hammer pull technique is great. If you do it, just be sure to empty your gas tank in-case and if you take it somewhere remind them, just in-case.
    Site Elder pt377's Avatar
    Mar 2011
    Riverside Ohio
    675
    67 times
    I hear if you hold dry ice on the center for a few minutes the pull back in a quick smooth motion it should pop right out. Let me know if it works LOL
    '06 650R Drag bars, Eliminator kit, stomp grips, Arrow black, & White Plasti dip 50/50 sharpie
    remember "Road Rash" on SEGA? Ill just carry a Chain
    Supreme Being steveinsandiego's Avatar
    north san diego county, ca
    2,676
    161 times
    i've never seen evidence to verify this technique, but i heard that if you blow hard enuff into the exhaust pipe the dent'll come out.............
    djrussell and TwinTurboDart like this.
    Site Elder barbos's Avatar
    Sep 2009
    Nashville, TN
    945
    151 times
    I had a dent in my tank, caused by me headbutting it during a crash. It did crack the paint, but I couldn't seem to find anyone that was willing to work with gas tanks. The ones that would, wouldn't touch it for less than $250-300, and that was just for the dent, no painting. New tank was only a bit more, so I ended up just replacing it.
    Jun 2012
    110
    I have heard of sealing the tank the best you can then pushing in compressed air. I don't know how many PSI it would be close to needing. You also chance deforming other areas of the tank if the dent isn't the weakest point.
    Jan 2010
    41
    Well I tried several methods with no success. I went ahead and had my local shop pull the dent and repaint the tank.
    Supreme Being Smash's Avatar
    Denver, CO
    6,805
    700 times
    What did it cost you?
    Jan 2010
    41
    I found a local shop that would pull the dent, and repaint including clear coat for $300
clip ons dent gas tank
diy motorcycle dent repair
fixing dented motorcycle tank
fuel tank dent removal
gas tank dent removal
gas tank dent removal tool
how to pull dent out of motorcycle gas tank
remove dent from motorcycle gas tank
removing dents from motorcycle gas tank
removing dents from motorcycle gas tanks
